FstFrd00
FstFrd00
www.gunsmithingtx.com
2021 BD Sasquatch
How do you like them?
They look good. The rears, I took the door panel off in order to remove the ripped up mesh. The machine screws, that it came with, were a little short.
My left leg does rub them while driving. So far they've been able to hold all the drinks, I do expect those big Stanley cups won't fit. Overall I like them.
  • Like
Reactions: Jdc
Reidt131
Reid
Howell, MI
Bronco Big Bend
Reidt131
Reid
Howell, MI
Bronco Big Bend
I installed a fire extinguisher mount for fun. A MAP torch was closest to me for the picture
You should get two of those mounts, one for starting fire, one for putting it out. Perfect prescribed burning setup lol!
FstFrd00
FstFrd00
2021 BD Sasquatch
I added some KO2, i like them thus far.
Got about 56k out if the OEM Goodyears, not bad.
Ford Bronco FstFrd00's Bluey Bronco 1000005865
I bought the KO2s used at about 60% tread life remaining and no patches/plugs nor irregular wear. All that to say they are load range E; I was hoping for C.
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Your Bronco is looking awesome!
FstFrd00
FstFrd00
2021 BD Sasquatch
Ford Bronco FstFrd00's Bluey Bronco 1000006010
Cheap tailgate reinforcement until I can afford the turn offroad one.
I took off the hinge bolts one at a time and replaced with m8 studs...I was hoping this was going to prevent a realignment of the tailgate..... I was wrong.
Is there a trick to get an 80lbs spare on the carrier, besides brut force?
Soon I am going to start replacing the speakers. Probably not a full sound system.... just replacing the stock speakers
FstFrd00
FstFrd00
2021 BD Sasquatch
Does this charger setup fast charge? Looking for something like this for mine, and because I have the Tackform mount the style of charger that goes on the accessory mount won't fit.
No
I bet you can buy one but it depends what power wire you tap into. Honestly I never use this.
FstFrd00
FstFrd00
2021 BD Sasquatch
Got a dash cam yesterday, haven't viewed any of the videos to see how good / bad they are yet.
Based on the LCD it looks good. Very simple install, basically stick it on the windshield, aim it and go.
Ford Bronco FstFrd00's Bluey Bronco 1741618005036-j5
