RynoRanger
Chuck
Gilbert, AZ
azbluey.com
2.7L Badlands NS 4dr
"bluey"... must be a dad. heh. (see my url in sig)
Summit981
Paul
Maryland
Porsche Cayman, MINI GP2, MINI Countryman
Mounted my 3d printed prototype BYOD rail. Still need to figure out best way to mount my phone. Leaning towards magnet. I wonder if I can glue a neodymium magnet to the base and sandwich a piece of steel between the phone and case?
If you plan significant off-roading (e.g. washboard roads), recommend mechanical mounts. Magnets typically won’t securely hold a phone under those conditions.
FstFrd00
FstFrd00
www.gunsmithingtx.com
2021 BD Sasquatch
So far, been to off-road parks quite a few times (I try to get out monthly or every other month). It's not the most secure, it shakes pretty good.
I run the front camera to a old tablet with a mechanical ball mount. I use it for my front camera..... much better offroad.
FstFrd00
FstFrd00
2021 BD Sasquatch
Pretty simple install.
I couldn't find my USB voltage meter , to verify Mabett's power claims. I will find out this weekend though.
All seemingly put out power. USB-A doesn't give me a slow charge notification. Both USB-C ports do....🤔
I like it but if the power isn't there, I might return it.
Ford Bronco FstFrd00's Bluey Bronco 20230511_200901
The power wasn't there. Mabett issued a full refund.
FstFrd00
FstFrd00
2021 BD Sasquatch
Installed the Rock Krawler 1" level kit. It is a spacer that goes on the bottom of the strut. I put it on a lift which made installation a lot easier. I was missing a couple of nuts in the hardware kit but we has extras.
Ford Bronco FstFrd00's Bluey Bronco InCollage_20230601_191421986
the new bolts are long....
Ford Bronco FstFrd00's Bluey Bronco 20230601_122647
Ford Bronco FstFrd00's Bluey Bronco IMG_20230602_103924
Ford Bronco FstFrd00's Bluey Bronco IMG_20230602_103927
Ford Bronco FstFrd00's Bluey Bronco IMG_20230602_103930
mjcutri
M
Lisbon, Portugal / Pittsburgh, PA
2023 Bronco HE
Mounted the DSS sliders and cut the front mud flaps (added an edge guard to cover the cuts)
I'm planning on doing the same mod with my mud flaps. What did you use for the edge guard around the cut part? Just regular door edge guard?
FstFrd00
FstFrd00
2021 BD Sasquatch
Yes, I bought cheap stuff for my other car and just used it
FstFrd00
FstFrd00
2021 BD Sasquatch
my drivers side Oracle Flush mount light was on its way out. Contacted Oracle and got a new taillight ~1.5 weeks later. I heard horror stories from my buddies, who had oracle lights on their jeeps, about Oracles CS. I had no such issues.
Ford Bronco FstFrd00's Bluey Bronco 396586753_287237720946467_917307346684753967_n
here is how it was.
The Bronze
Kelly
1986 Suzuki Samurai, 1967 Ford Bronco, 1993 Turbo Notchback, 2006 Sierra K1500, 2013 Sierra K1500, 2014 Sienna Mini-Van
here is how it was.
I have the same issue. Intermittent for a week or so (always worked for the camera) and finally failed just like yours on the same side. Just sent a message their way and hoping for the same resolution! Thanks for the info.
Tucker417
Garrett
Ozark
2023 Bronco Outer Banks
Did you do an alignment afterwards? If so, did it align to spec? Looking hard at getting this kit because of its price and simplicity.
FstFrd00
FstFrd00
2021 BD Sasquatch
I did get an alignment. I bought the lifetime alignment from firestone, some people have cautioned me about firestone as they have tried to upsale but I haven't had that issue yet. Usually ~30minutes and Im out.
The Bronze
Kelly
I just swapped out my light, which they covered under warranty quickly and without issue.
