- Chris
- Dec 1, 2025
- 8
- 62
- 110
- California
- 2023 Ford Bronco
- Badlands
I swapped my Badlands wheel for a Raptor wheel. The forum member I purchased the Raptor wheel from included a wheel that he modified to work with Raptor paddle shifters. So, I am selling two wheels. The silver surround and buttons are separate from the wheel, so if you just want the leather wheel, you can use your own buttons/silver surround.
I posted this thread showing how to remove the wheel: How to Remove Your Steering Wheel
Wheel 1 - Badlands Wheel, NO Auto Cruise Control, NOT Heated
This was removed from my Badlands at ~3500 miles, looks brand new, no wear. I removed the circuit boards inside the buttons to install in the Raptor wheel I swapped. If you are going to use the buttons/silver surround from this wheel, you will need to swap your circuit boards into the wheel. Info on this process on page 5 in this thread: Swap Boards You need a T20 and a T8 bit for the screws. I can walk you through the process if you have questions. It takes 5 minutes once the wheel is off.
SOLD - Wheel 2 - WITH Auto Cruise Control button, WITH Heat
This wheel was included as part of a sale from a forum member. The leather is in excellent shape, I do not see any wear. There are a couple light scratches on the bottom, and a nick on the left side, of the silver surround. If you are buying to upgrade to leather, you can use your silver surround if you are worried about the scratches, or if your buttons don't match.
It has heater circuitry (the red and blue wired harness). I am unable to test the heat function because my Bronco does not have that option, so I can't guarantee it works, but I have no reason to believe it does not. The forum member cut out some of the foam in the back and drilled two holes so Raptor paddle shifters could be mounted. If you can source Raptor paddle shifters, you can add them to this wheel. It does not affect the wheel, and you cannot tell that it has been modified when it is installed. Here is a writeup: Braptor Paddles on Badlands Wheel
I am in the San Diego area if you would like to meet. I am willing to ship, I estimate the cost at $60-$70. Please provide your Zip code if you would like an accurate shipped cost.
