Front shocks leaking. Will Sasquatch takeoffs do?
Bb_Bronky
marvin
SoCal
2021 bronco
So our front shocks is basically done. Looking to upgrade and maybe have a little more clearance. But not looking to spend a lot of $$. We have a 2021 non-Sasquatch Outer Banks 2.7 4doors. Will Sasquatch takeoffs fit and if it does anyone selling it? We’re in SoCal.
Valhalla
Valhalla
Chattanooga Tn
What are you looking to spend? might be the push I need to decide rides or 8112's.
Yes they will fit - but remember they were under recall for a long time there where the reservoir would fall off, and the fix basically amounted to gluing a shield on them just to keep the reservoir from falling off if it does break..
Neps
Floating off California
MX-5 30th, Focus EV, F150, Scout II (2)
I believe, although I'm often wrong, the recall is only on the rear shocks.
And Bilstein 6100 shocks are available for around $600 for a set, you'd need to get a spring compressor to mount them or have the work done for you. Still you get new shocks with the ability to lift without the unknowns of someone else's take offs.
Rick U
I just removed Sasquatch coil overs from my 2.7 2 door $250 in South Orange County. Not an expert, but I assume the springs would be a little lighter than a four-door. I don’t know whether Badlands have the same springs as other models. The Badland is a little heavier, so there may not be much difference, not sure.
Ford Bronco Front shocks leaking. Will Sasquatch takeoffs do? IMG_7043
Ford Bronco Front shocks leaking. Will Sasquatch takeoffs do? IMG_7042
Bb_Bronky
Bb_Bronky
marvin
SoCal
2021 bronco
Same I’m not an expert. But I think you’re right. But will keep you posted. I’m some what close to your area.
If you wanna pick up from CenCal, I have a set of Hitachis that you can have for free that have about 15k miles on them - it wouldn't be any sort of upgrade though.
Oldhippie
Barry
Santa Cruz, Calif.
I have my Sasquatch takeoffs (under 10000 miles) with 3” zone lift if ya want to come to Santa Cruz to get them…
Bb_Bronky
Bb_Bronky
marvin
SoCal
2021 bronco
Road trip? 😂 Will keep you posted. Thanks
