Front license plate mount options?
Nellman
Josh
Northern California unfortunately
2007 Toyota Tundra
I'll go with one of the shackle mounts myself. Don't really care if there's a plate up front or not, but I don't want holes drilled into my front in case I find a mount I like better. I'll make it clear to my dealer to NOT mount the plate and if they have to by some law, I'll supply the shackle mount. And eventually maybe come up with something I like better myself, if after market doesn't catch up. Strong magnets glued to the plate might work, just add some string hidden behind, just in case you hit a pothole and the plate comes free, keep it tied to the bumper anyways, even if flopping around.
We need them here for the toll bridges and lanes, so gotta have them if I want to use those. Never bothered me either, just don't like those drilled holes, goes against my OCD regarding hole drilling where not necessary.
I am going to try this with the manufacturer plate holder. Plate screwed into plate holder then magnets is the plan as of now. I am busy at work but will let you know how it works. Hopefully next week I will get this done.
  • Like
Reactions: Cat
Big Island Bronco ?♂️
Motown, Motor City, DeTwah, Detroit
XJ Cherokee, 1971 Z28 R/S
I’ll be using the Bronco bolts to attach my license plate to the front bash plate. There are various Bronco owners that have already done this. All you need is some 16 gauge metal and the ability to put a bend in it and drill some holes and you’re done. And anytime I do some heavy duty off roading I’ll just unbolt it.
Ford Bronco Front license plate mount options? 0D381719-908F-4C47-AE37-0488BAE0F25C
Ford Bronco Front license plate mount options? F8F56BD6-5309-41D1-8C74-6A22B14AA6A8
Ford Bronco Front license plate mount options? BB69220F-41DD-42A0-B7AA-E1363FD82729
Ford Bronco Front license plate mount options? 80B31A69-9DD9-4A65-95CC-0E370CA8CC91
Ford Bronco Front license plate mount options? 4662369F-1C71-4945-B262-ECD8B5AFF700
Ford Bronco Front license plate mount options? 1997A324-75A9-4499-A767-7D0354E33109
Gamecock
That looks great..but for someone that has no idea, where would you buy a piece of sheet metal like that? What would you use to cut it to fit?
Lowe’s and Home Depot sell it and if you ask nicely they may even cut it for you Or any small local shop would do it for you. Personally since I have a mechanics garage and all the accompanying tools for $12 and a half hour of my time I’ll be all set 😉
Ford Bronco Front license plate mount options? 0C057F9D-C3F2-477C-A41C-E124431E811E
Ford Bronco Front license plate mount options? EF791D32-BD40-4ABD-9B70-42890624C4C2
Ford Bronco Front license plate mount options? D2203B28-4D32-4DE8-8D5E-FA5F39D9A38A
This post has me thinking that instead of putting a forward bend in the plate steel to match the angle of the Bronco’s bash plate I will put a reverse bend in it. This will serve two purposes. One it will give the plate a bit more give if I bash it into anything and more importantly with this type of mount I can place the license plate up higher, just below the inter cooler opening. I’ll just have to drill two larger access holes in the mounting plate so I have access to the bronco bolts holding it to the bash plate. Once the license plate is mounted it will cover up those access holes 😉
Ford Bronco Front license plate mount options? CE6BB4C3-A154-4EF5-A368-36DBF3895B42
Ford Bronco Front license plate mount options? FC3E06FF-C42A-4E1C-B206-883B8E2D5DEC
CO-Bronco
CO-Bronco
Canada
www.instagram.com
2021 - 4dr - Cyber Orange - Badlands
CO-Bronco
CO-Bronco
Canada
www.instagram.com
I may try and make a modification to mount it with a locking hitch pin instead of the bolt - that way it can be quickly removed without tools if I need to attach a shackle.
Damn, that's a good idea.
peta8368
Norwalk, CA
2016 Polaris Slingshot
other than the swarfworks relocation bracket (marketed specifically for 2015+ f-150 and raptor), is there any other solution for the base(plastic) bumper?
604Bronco
British Columbia
www.bronco6g.com
2024 Toyota Tundra TRD Pro
Stupid question: Why steel? Won’t that rust? Any reason you didn’t use aluminum?
Not mechanically inclined at all. The fact I can tie my own shoes is a miracle.
HBTFD
Newnan GA
F350
I’m have this built this week. Trialing on Broncos soon, then for sale in a few weeks.
I haven’t actually built anything yet, I don’t even have a vin# for my 2-door First Edition Bronco. I currently live in Michigan which only requires a rear license plate but next year I’m moving to Hawaii so I will build a front license plate holder before I move. You do want something halfway durable like steel since it’s going to be down in front of the bash plate and most likely taking a beating like in my case. If you use steel you definitely need to apply a rust proof coating. Aluminum would definitely work for anybody who will not be doing any hard-core off-roading 😉
604Bronco
British Columbia
www.bronco6g.com
Thanks for the tips!
Whoever is the first to make these mounts on this forum will be a millionaire. I’d pay someone to make one for me and ship it.
MrGreen55
Kyle
Oregon
toyota scion xb
will your bend down or look like that picture?
Edit: @HBTFD
StickerFab
Fort Myers
www.stickerfab.com
2021 Bronco Badlands / 2023 Bronco Raptor
I'm going to run a batch with that upwards mounting design. Thanks for the inspiration there.
