ForScan Tire Size
Lordsandy
James
MA
What is the largest tire size you can upgrade to in For Scan without causing any issues?
Ducati1098
2880 mm
But unless you’re running 38’s or larger that’s unnecessary
Just a note:
ProCal / Forscan would let me set this large (I was running 2860 to calibrate the speed), I would get a silent DTC in the PCM (U0221? - not exact, going off memory) and it prevented Cruise Control from working
The largest I could set was 2779 (579 in ProCal) to keep the PCM code clear
