Surprise, it worked this morning. Also of note is that I have a light windshield tint, because SoCal. This does seem to be sensor-related.The double-click sound on the turn signal is expected with 726-43-01 — that byte enables the amber turn/DRL share but the BCM still sends two electrical pulses for the hyperflash compensation, so you hear it even when the light cadence looks right visually. Not a problem.
For the intermittent behavior: the most likely cause is the auto-light threshold. The BCM only activates DRLs when ambient light is above its daytime threshold. If you tested this morning in a garage, under a carport, or even with heavy cloud cover, the sensor may have kept the DRL circuit dormant. Try this: park outside in full daylight, engine running, headlight switch in Auto, wait 10-15 seconds. Should come on.
If it's still inconsistent after that, check whether you saved the write with the engine running vs just key-on. Some BCM blocks on the 2025 need the alternator active (engine running) to fully commit the write — key-on only can look like it saved but revert on next cold start.
