Form Headlight Signal issues
brneyemomma
Jessica
Louisiana
2021 Bronco Badlands (previous outerbanks)
Anyone here experience any issues with the signal randomly stopping working in the form Headlights? My passenger all of a sudden stopped signaling. The DRL works fine. The interior dash signal is hyperflashing.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Check to make sure it's plugged in all the way. Those plugs can be TIGHT sometimes and you may not have plugged it in 100%.
brneyemomma
brneyemomma
Jessica
Louisiana
They have been installed over over 6 months. I'll check the connectors and try to reset the negative on my battery.
Ridge
Ken
PA
2022 Bronco Badlands
MY Driver side DRL and high beam stopped working. Offroad shop was able to work with Form to get a replacement. Replacement works on passenger side but not driver side. Now trying to see if it is a BCM issue. Good luck and let us know how you make out.
dangerfoot
Justin
Austin TX
www.dangerfoot.com
White Wildtrak 4dr
I would just contact FORM directly. I ran into a little issue and they're fantastic to work with, I highly recommend their product and I'm sure they'll help you get it straightened out.
Ridge
Ken
PA
pinochle
Patrick
NNJ
2022 Bronco, 2018 Tacoma, 2013 & 2000 Impreza
I'm having the same problem with my driverside.
I reinstalled my OE lights and the issue persists. I'm pretty sure the Form lights took out my BCM.
Ridge
Ken
PA
So what I'm learning is that the BCM can "latch" or do a "hard disable" on the circuit. Only a Ford dealership can unlatch or fix the hard disable. I'll let you know how mine works out and please let me know if you find a solution. It doesn't necessarily mean we need a new BCM.
pinochle
Patrick
NNJ
Quite honestly, I've been dealing with this issue for months. Just haven't had time or the desire to bring it to Ford to figure out.
Hopefully it's an easy fix!
