Ford ProCal 2024 Bronco w/ 2.3
brian6674
2020 F150, 2017 Jeep Wrangler, 2005 WRX
I think a $30 ODB2 Bluetooth adapter with a phone app will do what you are looking for.
But beyond that - a properly registered procal unit will do that too, but I can’t confirm if it will work on a vehicle that doesn’t have the tune registered. It ~should~. But that doesn’t mean much
brian6674
I did something real crazy. I sent Ford Performance an e-mail asking the question. See if they get back!!!
The one I listed above has no tune, so is about $300 buck cheaper. Not really interested in the tune. But nice to have that option later if I change my mind.
brian6674
No response from Ford on my question........ :(
I’ll try to plug my unit into another truck and see what it does.
That said, I don’t know that there is a path to just buy the voucher code for the tune if you did want to upgrade to that later on. I guess you could always just flip the extra dongle if you did go that route.
As just a scanner, this is a very expensive and limited tool.
So I can’t say I would recommend what you are trying, I do kinda want to hear how it turns out (especially since it isn’t my money)
I would strongly recommend getting a Forscan-compatible adapter, almost all of them come with an app or have a built in screen that give you all the data you are looking for, and you get the option of using it for Forscan as well. For a fraction of the cost.
Or for about the same price, get a FDRS-compatible adapter, and then you have it for dealer-level work.
Just tried out my locked ProCal dongle on wife’s Bronco Sport
It does read the DTSCs fine, it does show engine/ECM parameters fine. I did not try to run any service/cal procedures.
But the basic stuff all seemed to work ok. It misidentified the engine in there - but I don’t think it was ever meant to work with the 3Cyl. Not even sure if there is an available one for the 2.0
But again, a Forscan compatible adapter will be way cheaper and do a lot more
brian6674
Thanks Brian! The Forscan stuff would work, or a app used with my phone. But I want somthing mounted, that will turn on/off with the Bronco. With no messing with it. I have one of these in my 2020 F150 and love it.
Edge 84130-3 Insight CTS3 - Touchscreen Monitor (edgeproducts.com)
I was just going to get another one for the Bronco. But looks like they don't support Ford after 2020. :(
Seeing Ford never got back to me about my question maybe I will shoot Edge one.
brian6674
Well, in under three hours Edge Tech support got back to me. They say it should work. They told me if I want to try, purchase through them, they would give me a 90 day return if it don't work. Hmmmm......
