Ford Performance Twin ARB Compressor mount doesnt fit.... Recommendations?
AK007
Washington DC
Awaiting my Bronco
Yesterday I spent a few hours trying to install the Ford Performance Twin ARB Compressor mount because 4WP quoted me 6hours/$900 + for install. Long story short I found out the hard way that it does not fit... I have a K&N air intake and the intake box that houses the filter is bigger than the OEM so there is not enough space for the bracket that bolts on the inner fender frame next to the filter box.
I'm considering the AGS offroad tire carrier, I looked at the vertical mount by Grimm Offroad but it seems like its tight next to the OEM air box based on the Your tube videos I've seen of the install.
Any and all suggestions welcome!
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
Someone out there was selling a bracket that oriented the compressor vertically, that might work. Hard to say without seeing a picture of that air intake. Maybe someone else can chime in.
swooshdave
Portland, Oregon
Mustang
There was another thread recently with someone with the same problem.
Lak34ers
Troy
Seattle
DV8 has a rear cargo holder
BroncoA512021
Long Island, NY
www.facebook.com
2021 Ford Bronco OBX
Darcyjs14
D’Arcy
Seattle
1970 Ford F250 Camper Special 4spd
+1 for dv8. Made my decision after reading another forum member’s post. We both have Braptors but the DV8 mount system was designed for all Broncos, it just installs slightly easier in Braptor.
AK007
AK007
Washington DC
Awaiting my Bronco
I'd say ditch the K&N.
I would, but its a day and night difference in power and immediately noticeable on the first drive after install. Its on my top 5 fav mods and would definitely recommend along with the ProCal.
Migo
Roy
Houston, TX
www.instagram.com
I ran into the same problem with my Mishimoto intake and under hood mounting options. I ended up mounting my compressor on a molle panel in the cargo area. I ran all the wiring along the frame and back into the cargo area via one of the grommets. If I did it again, I would likely run the wiring through the existing wire run on the passenger side, under the sill plates. With that said, I have been very happy with the results.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
AK007
AK007
Washington DC
Awaiting my Bronco
Pics of the K&N
Ford Bronco Ford Performance Twin ARB Compressor mount doesnt fit.... Recommendations? IMG_4228
Ford Bronco Ford Performance Twin ARB Compressor mount doesnt fit.... Recommendations? IMG_4227
Ford Bronco Ford Performance Twin ARB Compressor mount doesnt fit.... Recommendations? IMG_4181
Ford Bronco Ford Performance Twin ARB Compressor mount doesnt fit.... Recommendations? IMG_4183
4x4TruckLEDs.com
Adam
Lindenhurst, NY
I find that i'd rather have an onboard Air Compressor over an upgraded air filter. The upgraded air intakes honestly don't do much of anything. The stock air intakes work just as well then the aftermarket ones.
