Ford Performance Fairlead
BK1
SC
C8, GMC At4, BMW
Does anyone know if the Factor 55 / Ford Performance fairlead will fit stock everglades?
RagnarKon
Ford Bronco, Escape, Focus
I believe it will, yes.
It's the same fairlead that comes with the Ford Performance winch kit, which includes 95% of the same components as the Everglades winch.
Picture below (with the license plate bracket installed).
Ford Bronco Ford Performance Fairlead 1705880072613
BK1
BK1
SC
C8, GMC At4, BMW
Thank you
Ordering red factor 55 ultrahook and may grab this fairlead too!
RagnarKon
Thank you
Before you order.... be aware you may have to beat on the winch rope it to actually get it to fit. (Did the exact same install a few weeks ago.)
11 minute 45 second mark.
BK1
BK1
SC
C8, GMC At4, BMW
Does that even have to be on there?
Fasteddy
Ed
Oregon
2023 Bronco 2 Door, 1992 F150 4x4
Factor 55 also makes this.
Spool
  • Like
Reactions: BK1
RagnarKon
Spool
True, up to you if you want to go through the hassle.
The only way to get the thimble off is to cut it off. So you either got the cut the steel and hope you don't damage the rope. Or you cut the rope and re-splice.
Or beat it with a hammer. :cool:
Fasteddy
Ed
Oregon
FWW, You do not cut either the rope or the steel tube thimble, you 'de splice' / re splice...
watch the video on the web page...
RagnarKon
It’s a Brummel lock on the end of the Warn winch line, so the only desplicing you’ll be able to do is pulling the buried tail out. After that you’ll likely have to cut it. Once that knot is tied and weight is put on the line it’s locked.
Factor 55 themselves recommends—or used to recommend before Warn bought them—a long bury splice, which you can desplice even after weight has been put on the line (though it takes some work).
I do agree that cutting the metal thimble is a bad idea, but for someone who hasn’t spliced before and doesn’t have a fid, I could see them thinking about making the attempt first.
Fasteddy
Ed
Oregon
Thats good info, My Ultrahook should arrive today and I have not had a load on the rope yet, after watching the videos I ordered the spool and fid from Factor 55 so well see where I end up. I already had issues getting the thimble through the fairlead and had to hammer on it.
Ninjak
Miami
I have an ultra hook from 55, all I needed to do was take the pins out of my flatline and install it. But I answered the question, I already had a flatline on it, so the end of the rope was already done.
BigPapaC77
Collin
Winter Garden
2023 Bronco Heritage 4D
Thank you so much for all the videos you make. The stereo series was absolutely invaluable to me replacing everything in my '23 Heritage. Really enjoy the content.!
