Ford mesh bimini top question
Bt_ostate
Oklahoma/Colorado
2021 Ranger Tremor 2021 Bronco 4-Door FE
For those who have installed this on a 4 dt with mic top: can this mesh top stay on under the mic top so you don't have to take it on and off??
jamtra
james
grand rapids, mi
f150
Yes. I ordered mine and the dealer put it on under the mic top. I took it off though but it does work.
kodiakisland
Arkansas
Yes. You can also install it with the top on.
Ohhellothere
Düåvé
Boston
Anyone have photos of it installed with the MIC hardtop?
nolencl
Clint
Dallas, TX
2022 Ford Bronco Badlands 4-Door Sasquatch Lux
Here you go. OEM mesh Bimini installed with hard top.
Ford Bronco Ford mesh bimini top question 99DAA82D-C49F-4550-B0A1-A2AEDD73462A
Ford Bronco Ford mesh bimini top question 039369C4-0463-4751-916D-467D331323FA
nolencl
Clint
Dallas, TX
That’s about as taught as I can get it. Wish it was better for sure!
nolencl
Clint
Dallas, TX
Yeah, the problem is that you have to fold the front flap back in order to engage the two front latches for the hardtop and without that front flap of the bikini top attached at its three attachment locations, the bikini top can’t be very tight. It’s not like it hits your head (I’m 6‘2“) but it doesn’t look amazing.
SD_Bronco
Hetal
97 4Runner (Sold)
hey guys, opening up an older thread but couldnt really find info on this. I am thinking about using my ford points to get the besttop bimini, what are your driving impressions? Is it really bad on highway? thanks
HenryGX
Henry
Curious about reviews as well. My uncle is highly considering the bimini top as one of the next mods after mounting the brake pads and tires from 4Wheelonline this week.
JTopsUSA
www.broncosunshades.com
Ram 1500 diesel,
Here is a JTop. We know you can’t use Ford points but we do offer a $25 discount to forum members.
Bestop makes absolutely great products but they might have missed the mark slightly on this one.
Ford Bronco Ford mesh bimini top question IMG_6066
Ford Bronco Ford mesh bimini top question IMG_6032
Ford Bronco Ford mesh bimini top question IMG_5426
Ford Bronco Ford mesh bimini top question IMG_5416
mike8675309
Minnesota
Only recommendation is that if you are using a DIY or purchased lift to lift the top off, you will find that you won't want to have the bimi under the top as it gets in the way.
Otherwise, they work fine. The factory one has several straps that can be flappy at highway speeds unless you carefully tuck them under things. Also, the leading edge of the factory bimini uses magnets to keep it flat, and they are not strong enough to do so at speed so that the leading edge can pop up. This just adds some noise.
