Ford Dash Camera
Patrickgault
Patrick Gault
South Carolina, USA
Ford Bronco, 2022 Outer Banks.
Anyone know what the difference is between the two cameras listed at the top? Please post a reveiw of the camera's if anyone has experience with them. Thanks!
Ford Bronco Ford Dash Camera Screenshot_20230602_145616_DuckDuckGo
TheKim
Kim
I do not recommend overpaying for the crap from Ford.
Personally, I recommend the A119 series, or the Blueskysea 4K (my current dashcam).
Reddit also has a list you can browse through -
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
That REDDIT list is complete crap!
TheKim
Kim
1st 75th ranger
jeffrey
nj
i r will see better at night
cdcsf
SF Bay Area
MB Sprinter 4x4, '22 Ford Bronco
The IR rear facing (the first one) most probably is a rear facing camera (positioned on the windshield) to record inside the vehicle. The rear facing camera for the second one is designed to record behind the vehicle (positioned at the rear of the vehicle).
BlueBronco
DFW
The IR rear facing (the first one) most probably is a rear facing camera (positioned on twindshield) to record inside the vehicle. The rear facing camera for the second one is designed to record behind the vehicle (positioned at the rear of the vehicle).
This is correct.
However, these particular cameras are over priced through Ford and the same ones can be found a lot cheaper. However, if you have points to burn and no other accessories appeal to you then they are essentially "free" anyhow.
I have a BlackVue cam in my Bronco but will probably buy 2 of the Ford ones to outfit my wife's Bronco and my F150 simply because I have an F load of points, Ford accy catalog is weak and I do my own maintenance.
