Ford cargo area enclosure - unlocking options?
Jak
CA
I plan on getting the cargo enclosure to prevent smash and grabs. But I was at a bronco event this week and played around with the locking system, and find out if somebody broke the front window and pressed the unlock button on the inside of the door, they would be able to open the back and have access to the cargo enclosure.
The enclosure prevents people from seeing what's in the back, but it'd be great if they couldn't have access to it. Is there an option where unlocking the back is separate? Maybe in the software?
This is the enclosure Im referring to:
https://accessories.ford.com/products/bronco-4dr-2021-deluxe-raised-lid-cargo-area-enclosure-1
Ive seen the security draw but it's too small.
Theherofails
Thomas
Phoenix
The tailgate won't unlock the doors, but I've never actually checked if the inverse was true. What a glaring oversight, if true. I've only ever unlocked the tailgate with the auto unlock when it senses your hand. Eesh.
The only thing I've seen that even comes close to what you're asking is the Rough Country security box. Its not quite a full cargo area of security, though. Still, much better than none at all, or the OEM box which is less than half as tall.
The nice part of this design from my perspective is the open area on the bottom is both still usable, and allows access to the bottom storage bin.
https://www.cjponyparts.com/rough-c...ZXy9nLoWPPhRb56QH4XTOoFTmAY15SwhoCyQ0QAvD_BwE
Ford Bronco Ford cargo area enclosure - unlocking options? 1636696641644
I'm not affiliated with the link, just chose one at random.
16G steel is "ok", but its not going to stop a determined thief. Luckily, very few are.
SolidSnake
Dante
No
I have the rough country one above and like it. I had the enclosure and was not happy with it. If someone does break into your car they will not waste the time to pry open a drawer
  • Like
Reactions: Jak
Lifeliberty
Moonbeam👀
Columbus, OH
Daktari
Oliver
I'll have to take a closer look at this one. I want something lockable but still want enough head room to have a sleeping platform on top, the Ford cargo box is way too tall, this one might just work. I'll also look at the security drawer, I won't need much lockable space, but some things I'd like to keep out of easy reach when out exploring.
  • Like
Reactions: Jak
Jak
CA
I remember seeing something like the cargo enclosure, but it had another door. Anyone remember seeing that?
Jak
CA
Surely there's a way to fix this, maybe playing with some wires??
OU812
Spinderland
2020 Ford Exlporer
If someone wants what’s in your car, they’ll get it. Most times, they’re just looking for cash and things that can be easily grabbed, so if you slow them down your chances of keeping what you got are that much higher.
Aurongel
M.
Austin, TX
2016 Dodge Challenger RT
This scenario has been discussed before on here. I believe the interior lock/unlock buttons deactivate after the fob is outside the vehicle’s range for a period of time.
GT500
Chuck
Maine
2018 Mustang GT
Interesting topic.
I'm so glad I live in Maine, I rarely lock my doors.
nottinbe
St. Louis, MO
This is correct. Once locked with the fob, there is a timeout after which the door lock buttons on the doors deactivate. It's a setting that can be changed, but by default behaves this way. So the tailgate and enclosure remain secure even if the top is down, or someone somehow gets in the vehicle. Combined with the keypad, this also allows for leaving the fob in the trunk\enclosure even with the top off or doors off.
Jak
CA
That’s good news, hope this is true.
MikeStLouis
St. Louis, MO
2022 Bronco
Does anyone know if the Cargo Enclosure is solid enough to keep things safe with the roof off? Can it be cut through? Broken?
Need a place for gear to be kept safe with the top off.
Thanks a bunch!
Ares
Fox
Atlanta
Thanks a bunch!
Id say youd have that open in about 45seconds with a sawzall, maybe less with a prybar.
this will prevent casual mischief makers in the grocery parking lot from yanking a loose backpack out of your cargo area.
If someone is more committed, they will absolutely get in. 99% of locks can be opened with a $2 wave rake in a matter of seconds, the locks on most of these security boxes is just cracker jack security. Sadly, you often wish thiefs would be so nice as to just pick the lock, most prefer a prybar and cause more damage in opening the device than they get from what might be inside. (I dont think this box has a lock on it though, I think its just secured by the closed liftgate)
Thats part of the reason I hesitate to get a locking box, it gives the illusion of potential valuables. worse if you actually keep valuables, but still annoying if they cause damage only to reveal you were securing nothing.
MikeStLouis
St. Louis, MO
2022 Bronco
Some of the “off brand” boxes are built so that all you can see is metal. So it would take some kind of rotozip with a metal cutter to get in. Just wasn’t sure if this Ford one was some kind of metal mesh that couldn’t jsut be easily cut into.
thanks
