Fog lights for Base Model
Bbaliatico
New Jersey
2022 Bronco
I just got a base 4 door and have been looking for fog lights. I’m going a little old school look, eg, keeping steelies but with 285’s.
See picts as fillows
- fog light oem part with no lens/bulb that has no bulb or lens and is $184
- $33 pair from Amazon with yellow lens and no bulb
- $17.99 light with clear lens and H11 bulb included from amazon
- up close pictures of the $17.99 In hand
is it me or is the same part?!
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Bbaliatico
New Jersey
2022 Bronco
I have a base, no fogs at all. The links were pictures of entire fog lights that look identical to the Ford part
Meals20
Meals
Maine
2010 Frontier, 2008 Focus, 2008 Sprinter
Nobody is going to be able to answer your question because your picture links are bunk.
I am going to run with these on my base bumper no factory fogs. I have the lights but no Bronco. https://www.4x4truckleds.com/diode-dynamics-stage-series-3-sport-yellow-sae-fog-flush-pair/
Bbaliatico
New Jersey
2022 Bronco
sorry for the mixup on images, not sure why that happened.
Ford Bronco Fog lights for Base Model IMG-2735
Ford Bronco Fog lights for Base Model IMG-2731
Ford Bronco Fog lights for Base Model IMG-2726
Ford Bronco Fog lights for Base Model IMG-2734
Meals20
Meals
Maine
Will you be buying the factory plastic housings on the bumper to accommodate these cans or cutting the ones that come on it?
Bbaliatico
New Jersey
2022 Bronco
I would prefer to buy the housing but I could not find the part. Still looking. Otherwise, hole saw.
Meals20
Meals
Maine
The Amazon housing might fit and might not? It might share the same bolt up pattern but housing dimensions are off. The Ford p# listed there doesn't cross reference to the Ford p# listed for the Bronco. The Bronco housing p# is the same for 19'/20' Ranger. Imho the aftermarket options are the way to go. You can get kits with lighting and harness ready to go from Forum sponsor @4x4TruckLEDs.com
Tarheel_Wes
Wesley
FJ
They fit. Anyone know the part # for the bumper cover with the fog opening?
which bumper do you have? Is this the modular bumper or the plastic base ?
Bbaliatico
New Jersey
2022 Bronco
Yes, the base plastic bumper. You can see the bumper cover is removed on the left. There is a standard replacement that fits exactly, but has a hole for the light. One right, one left.
M2DZ17E811DA
M2DZ17E810DA
Meals20
Meals
Maine
Bbaliatico
New Jersey
2022 Bronco
Yes. One is on backorder. Found an online dealer selling for $54 vs $80 list too.
Bbaliatico
New Jersey
2022 Bronco
So, the factory fog light bumper panels are on back order. I test fit the $17 Amazon fog and it fits the mount perfectly. I found the center of that part of the panel and used a 3-1/2” hole saw to make the cutout. I’ll still put in the factory panels, but if anyone wants a factory like fog setup, $34 and a hole saw (less the wiring).
Ford Bronco Fog lights for Base Model B7C65B55-8F90-4897-86A2-792F605B282D
2ata
Bob
Curr.: 2021 Ford Bronco; '77 924, '01 986, '02 911
What are you doing for the bulb plug and wiring?
