Floor heat non-existent?
Mean Red GT
Kevin
TN
2022 4 Door Badlands/2016 Mustang GT PP
So from this it looks like the yellow ones are feeding the back and the purple one on the left is the only one on the front floor?? So nothing on passenger side front??
flip
Phil
IN
www.ruxerparts.com
Fords
The other purple one 18C298 is the passenger side. Looks like a turndown or just a stubby duct.
bikearch
Los Angeles Ca 91423
2014 camaro
Yeah it is annoying but thankfully I am in so cal where its not that big of an issue. Was up in zero degree weather last week and it also was not a issue though i had my asolo boots on!
ex_nyer
Chokes
Connecticut
F150, Land Cruiser, Outback
Yes. While not a good substitute, the seat heater roasts my arse to the point I forget my frozen feet.
The heated seats and steering wheel for those who have it really work well. The dash vents are also super hot.
Paul Gagnon
Paul
Sherwood Park, Alberta, eh?
'79 Mustang, '92 Explorer, '10 F-350
The amount of air coming out the floor vents is less than I was expecting but it is there.
Jazer
Jessica
2.7 OBX
Any new info on these? Even on floor heat blowing max I don't seem to feel any air flow coming out at all. My daughter could feel the warm air when I aimed the upper center vents at her and the car retains heat well, so it's not the end of the world - I just want to make sure I'm not overlooking something silly.
flip
Phil
IN
www.ruxerparts.com
Fords
Exactly. I think there's plenty of air volume available, just need to choke the defrost vents down some and maybe the dash a little to force more out the bottom. The windshield is small and doesn't need as much flow as the F150, Edge or Explorer.
JohnnyBronco
Pennsylania
X4
Are you sure you are
1. push button dash that displays air movement
2. select where you want airflow
3. Every time you start - repeat since it will not hold settings from one session to another
If you start with windshield on high and then put fan speed down to 1 or 2 you can sometimes get heat - but the problem (#3 above) is that heat settings selected won't stick
talbot
Calgary
2dr BL AMB
I had the dealer check mine, they indicated a duct on the passenger side wasn't installed correctly and fixed that
minor improvement, think the overall design is lacking
strangely enough I've found that having it set for auto puts more heat to the floor, though I might be just telling myself that
Jazer
Jessica
2.7 OBX
Yeah I did do all this, I am going to go mess around with it some more later though.
Ksjrb03
Tx
F250
I haven't played with it a whole lot, but it seemed to me like way too much air was coming out of the defrost vents and nothing out of the floor. The rear vents might as well not even be there.
esquared
PNW
'21 2.7 BD
Twice now I've had an issue where the dash vents weren't blowing even though I selected them in the directional menu. Each time I opened the menu, de-selected, then re-selected the vents and then they started blowing air 🤷‍♂️
I've had a couple other issues with the electronics:
1. Once had no touch response for android auto, had to restart car
2. Then a couple times the system didn't initially recognize any of my inputs...I would start car then try to change audio channels, volume, and temperature, using both the steering wheel controls and dash buttons/wheels, none of these did a thing, then about 1-3 minutes later ALL the button clicks/nob changes I had made just suddenly occurred in like a mass spamming moment. It was as if there was a blocking startup process that delayed any input.
All has been good for about a week though so maybe a software update fixed them?
