Fitment Help with Mudflaps
txfuncars
22 Badlands 2.3 7M 2DR, 93 Mazda Rx7
I purchased the front and rear flaps for a '22 2DR Badlands with the rock rails. I am having a couple of fitment issues and was hoping for some help.
1. On the drivers side, the metal bracket is at a bit of an angle and as such the flap actually touches the rock rail at rest, is this by design? Pictures I've seen show a fairly decent gap between the 2.
Ford Bronco Fitment Help with Mudflaps PXL_20240425_141603512
2. I can't get the passenger side on at all due to the hole for the plastic clip (inside most hole) not lining up. I can get the clip in, but at such an extreme angle it doesn't secure properly. Hard to get photos, but below you can see the "U" cutout is touching on the bottom of the rail/bar and still not close enough to the hole to fit.
Ford Bronco Fitment Help with Mudflaps PXL_20240425_002132090
The "U" shape is touching on the bottom and can't go up any further to meet the hole in the fender.
Ford Bronco Fitment Help with Mudflaps PXL_20240425_002121460
Fuzzy pic, shows the hole doesn't line up.
Ford Bronco Fitment Help with Mudflaps PXL_20240425_002933502.MP
hard to see but the plastic clip is a pretty extreme angle to clear the hole, and as such won't screw down and secure.
Ford Bronco Fitment Help with Mudflaps PXL_20240425_003414289
For reference, here's the fit on the drivers side which is spot on (besides the wonky metal bracket).
I haven't bothered to do the rears yet as I want to see if these will actually fit my vehicle.
Thanks in advance!
Fordified1
Bob
Mid South Texas
Are these the Chinese knockoffs of name brand parts? It’s plastic, modify to fit, slot the bolt hole. Don’t worry about the flap contacting the rock rail. Nothing is perfect, there are allowed tolerances and sometimes stuff just doesn’t line up perfectly.
Take the crash bars off if you want.
txfuncars
Definitely not removing crash bars for mud flaps...
These are the Mabett set (hence this sub-forum), and they have pretty fair reviews and videos as I've seen around here.
I have no problem cutting them, but if the fit is a poor as I'm experiencing maybe it's a bad set or more systemic to the product, hence my post.
Fordified1
Bob
Mid South Texas
I have the same Chinese mudflaps. And they seemed to fit ok. I’m not running crash bars because I’m running 35’s, so no clue how they would have fit with the crash bars installed. I think they contact the rock rails but I don’t care. They look great and do their job for a good price.
bkirchhoff
Middlebury, VT
BMW: '07 328xi, '13 X1, '75 R90/6, '12 R1200GS
As for the rubbing on the rock rails, that’s how mine sit in there too and that’s what the sheet of sticky felt is for — to mitigate the metal on plastic rubbing.
With your other issue, I don’t think I experienced this if I’m understanding the photos. I believe that hole lined up fine on mine.
I finally installed the rears last week and the bolts they include are different from the instructions so that two of them stick out inside the flaps. I think I’ll just cut them down to flush and forget it — but as another person said, cheap Chinese parts just have to be modified sometimes. The real solution is to upgrade to better quality parts at 2-4x the cost. So I’m making due with these for now and won’t cry if I destroy them and need to replace them.
Fordified1
Bob
Mid South Texas
They are great for the price, and who’s to say which bolt holes are slightly off… Ford’s or Mabett’s?
Ford Bronco Fitment Help with Mudflaps IMG_0495
txfuncars
@Fordified1 Lol fair enough, I can blame Ford or Mabett!
I did end up dremeling the holes out to fit, and the rear was a bit less painful, although I had to squeeze some plastic to get them lined up. I will be finding some shorter bolts so they aren't so obvious as well.
My purpose of this thread was to see if I got a funky set, or if the fitment was a bit over the place with these. Sounds like the latter, but for the price I am happy with them.
My most common use for the Bronco is going to be mud + pasture driving, not so much rock crawling so I figure they will last for quite a while.
Thanks all!
Ford Bronco Fitment Help with Mudflaps 1714145541526-2a
Bill K
Allen, TX
Ford Bronco Big Bend 2 Door
Precisely what I did. Had to slot the holes in order to get the push pin in on one side. Drill press made quick work of it...
Stevenson James
Chicago
2024 Bronco
I installed these mudflaps on the front last weekend. I noticed with them attached, it was a bit hard to lock the fender flares back on. I had to back out the top screw in order to flip the fender flare clip. But my main concern/question is, the threaded clips that you have to install in the fender liner area... thats just metal on metal, i was surprised there was no rubber insulation or anything between the clip and the metal. Should i be concerned about rust there?
Fordified1
Bob
Mid South Texas
The clips are zink plated I believe and the fender is aluminum. Not sure if the bolts are stainless but that would be nice. Small to no concern about rust…. Look under your Bronco, there’s a crap ton of bare steel under there that is definitely going to rust.
Stevenson James
Chicago
2024 Bronco
Thank you for the piece of mind! I appreciate the response.
