Finally Frame Mounted Sliders from LOD OFFROAD!!!
Status
Not open for further replies.
wilbersk
Sean
2023 Bronco Raptor
All three of our sliders (Armor Lite, Destroyer and Signature) will use the same mounting. We do recommend drilling if you plan to use them for anything more than a step. They are bolt on with several bolt locations and will work fine as bolt on only for a step. However the front mounting area on the frame lacks sufficient bolt locations for use as a slider, so we recommend drilling those at least.
We have not encountered any wiring inside the frame rails, but there are wire harness and brake lines on the outside of the frame. These will not be a problem during installation. We had no issues drilling our frame, just need a drill and a few good drill bits, easy.
Is it possible to weld them to the frame?
GreenMtnBronco
West Nyack NY & Central VT
'21 BadSquatch; 04 Lifted Mini
LOD Offroad
LOD Offroad
LOD Offroad
Indiana
lodoffroad.com
Jeep Wrangler JLU, Jeep Gladiator, Bronco
Sure you can! However the Armor Lite and Destroyers come with individual mounts, so wouldnt really make sense to weld those unless you weld everything together after install.
cricex
Charles
Austin, Texas
2.7L CG Badlands Sasquatch
When will these be available to order?
GreenMtnBronco
THnCS
Tim
Colorado Springs
22 2dr Bronco Badlands 19 Chevy Silverado
Are these for 2 or 4dr? Nothing on the website tells you that.
Status
