Fan humming after shutting off engine
TXBronco1313
2024 Wildtrak with 1,500 miles so far. Today was the first time I notice a faint fan noise after turning the Bronco off. Coincidentally, we had hot weather today so I’m not sure if it’s weather related or something might be overheating. Oil and trans temps were very normal. Hoping to see if this is normal.
Normal for a lot of stuff to stay running after the engine is off. It should shut off after a few minutes.
Even your headlights have cooling fans
TXBronco1313
Yep it did shut off shortly after but I just wanted to confirm because I’m a little traumatized from all the issues I see on here so I wanted to double check nothing was going on 😅. Thank you!
lakesinai
Charleston SC
No need for trauma. The forum will highlight all the things that can go wrong with a Bronco, which is what forums are for. But there are many if us with problem free cars still chugging along . . . My 2021 OBX 2.7 auto trans is problem free at 67,000 miles.
