Factory Subwoofer works sometimes- help!
Hunter05
Willis, Tx
2023 2 Door Bronco
I just traded in my 2023 big bend. It had the subwoofer delete. I received my new 2023 black diamond last week. About one out of three times that I start it and drive it, the factory subwoofer is not playing. if I turn the bronco off and turn it back on, the subwoofer plays with the music. It’s going to the dealership later this week, but I was just wondering if anybody else has experienced this. I cringe at the thought of them Pulling interior panels to try to find the problem. Less than 200 miles on the new rig. Thanks for your time.
soldier989
Brett
Ohio
2023 Bronco Base MT / 2021 MX-5 GT / 1966 Ford F10
I had to install a factory 2023 into my 2023 with the sub delete. Its been installed for about 2 months now and has not had this occur a single time. I'm unsure if you have the base 7 speaker or the B&O, but with either setup, maybe you could try doing a master reset or reseat the fuse. Just some ideas before having the dealer do their damage.
B-Dog15
Brandon
Covington, Ky
2025 Base 4-Door
Reviving this thread to see if you ever found a solution? Mine does this every once in a while just wondering of there is a known cause/fix.
