Factory roof rack removal from MIC
BOLD Renegade93
Bossier City, LA
2021 Ford Bronco Black Diamond
Alright folks, I'm at a loss here. I've watched Ford's YouTube video and the one by the dude at Bronco Nation who makes terrible jokes. I followed each step exactly in order when it comes to removing fasteners and such for the roof rack removal, but when I go to lift the rack off like the videos show, it doesn't lift off. It'll raise up some but there is a metal clip that extends under the lip of the MIC top just enough that it won't allow the rack to be lifted off. Has anyone with the factory roof rack been able to successfully remove it with ease or are there others as frustrated as I am?
@BadBlueBronco
Kc
Los angeles
2021 Bronco Badlands
Following in case I have an issue.
From what I remember the rear section is “clamped” onto the MIC. Maybe you need to loosen the clamp more so the ledge unseats. I am getting mine in a few weeks so I’m not speaking from experience.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Did you remove the triangular head bolts from the rear mounts?
BOLD Renegade93
BOLD Renegade93
Bossier City, LA
It is clamped to the MIC, but I've loosened the triangle bolt all the way and the lip of the clamp doesn't clear the MIC edge. It gets close but nowhere near the video where they literally pick the dang thing up and remove it without any resistance. I'm sure Ford made it so that those guys didn't embarrass themselves lol.
BOLD Renegade93
BOLD Renegade93
Bossier City, LA
Yes I did. I tried that and I also tried just loosening without removing them. Same result for me. It definitely gets loose and tries to lift off but that dang metal clamp still gets caught
Broncolli
MD
'21 Back Diamond 4 door MIC
A different issue I have with the same video - I have the factory roof rack - but I cannot remove the front panels with the rack installed. Even after opening the locks/clips and then folding the front back up - the panel still gets caught on that front clip bracket. The locator pin is what gets caught.
BOLD Renegade93
BOLD Renegade93
Bossier City, LA
Pretty sure the rear crossbar just presses into the two end clamps. Grab one of the end clamps and tug it towards you, away from the vehicle!
Yeah it kinda does. It sits on the clamp with a rubber dampening liner in between to reduce scratching and rubbing. The clamps can't be pulled enough to clear the lip of the MIC. At least I haven't figured it out yet. The video is so misleading, which is part of my frustration. The two guys literally lifted it off like it was just resting on top of the roof.
BOLD Renegade93
BOLD Renegade93
Bossier City, LA
Does this help? Maybe work the installation in teverse
I don't think so but I didn't try removing the rear cross bar. It doesn't say to in either video but it's worth another look. Appreciate the photo though.
WuNgUn
Ontario Canada
2 door Squatched
Kinda does? Lol
Pull harder 🤷🏻
BOLD Renegade93
BOLD Renegade93
Bossier City, LA
Kinda does? Lol
Pull harder 🤷🏻
Yeah I might try that next time. It didn't seem like it wanted to release with a good amount of effort so I wasn't willing to mess up a brand new roof rack/Roof without further research.
PNWAdventurer
Everett, WA
2012 Range Rover
I took my roof rack off a few days ago and had the same issue. The clamp didn't want to slide enough down or out to clear the roof channel. I took the top cover off so I could see how the clamp worked. The clamp is suppose to slide down as you loosen the triangular bolt but that wasn't happening. I ended up placing a small screwdriver between the roof and clamp where it clips into the channel. I slowly and carefully walked the clamp down enough to clear. It was frustrating for sure but I was able to get it off. I'm hope it is just from being taken off for the 1st time.
BOLD Renegade93
BOLD Renegade93
Bossier City, LA
Yeah I honestly thought about doing this but wanted to see what experience others had doing it first. I might try that next.
webspoke
Stan
Pilot Point, TX
F450, GT350
They are sticky under the the triangular bolt. I had one side that dropped down and out of the way, the other needed some prying to break free and slide down and out. keep wiggling it with a bit of screwdriver prying and it will work.
