Factory rock slides - add on drop step?
TahoeTexan
Tod
Reno, NV
2022 Bronco OBX
I thought I saw a version of an add on step that will mount to the factory rock slides with a few inch drop. I did find IAG makes a version that sits 2" below the top of the factory slide:
IAG 2" below
Are there any other options that are a little bit lower?
RoLyMa27
Rodney
SloKart, TX
21 Bronco 2dr, 26 Explorer ST
The only other step that mounts to the rock rail I know of is Archetype Racing. I think theirs sits level with the rock rail.
Kos
Omaha, NE
2022 Ford Bronco Badlands
IAG 2" below
IAG is looking at a version that is another 2” lower, but the interest wasn’t there on the poll they took. I think they are still planning on it. Just wasn’t a priority.
that said I got the 2” drop and it’s enough for my 6 year olds to get in and out.
TahoeTexan
Tod
Reno, NV
2022 Bronco OBX
Cool. I have the OBX with running boards but I'm planning on larger tires and switching over to rock slides with a step.
What size tires and do you have a lift?
Kos
Omaha, NE
Standard badlands. 33” tires. I think the badlands sits an inch above the OBX, .5” below SAS in terms of lift.
Ksjrb03
Tx
F250
SAS is closer to 2” higher with the lift and bigger tires.
Fly2Win
Chalfont, PA
F250 SD, 68 Firebird, 85 300ZX
Just installed v2, on 2 door BD SAS
Now I know what mine will look like when it is built at the end of the month, thanks! V2s on order.
TX-Hans
IAG 2" below
The AR Stirrup is another option that attaches to the OEM rock rails. And, it is adjustable to either be even with the top of the rock rail or 2" below top of rock rail. Don't have to decide between two versions when ordering.
https://www.bronco6g.com/forum/threads/ar-stirrup®-oem-rail-fitment-billet-aluminum-side-step-brongo6g-exclusive-part.26196/
Kos
Omaha, NE
Yeah. Maybe I wasn’t clear. 35” tires vs 33” adds an inch in height. The .5”-1” difference in lift works out to a 1.5”-2” difference in height at the door sill.
Ksjrb03
Tx
F250
Ya that’s what I was talking about. It’s 1.8” at the door sill for step in height.
