Sold: Pennsylvania f/s: Oracle flush mount tail lights w/ dual function reverse turn signals
WildtrakBronco
Pennsylvania
2022 Bronco
As the title implies, this is a set of the lensless, flush style LED tail lights for 2021-2025 Broncos. These are the standard red lens variant. (https://www.oraclelights.com/products/bronco-flush-tail-lights?variant=40830053548129)
Installed are the optional dual function amber/white LED modules (https://www.oraclelights.com/produc...onco-flush-tail-lights?variant=40825581633633) This allows the turn signal to use that light rather than the outer red to blink. (I liked this because it more closely resembled the behavior of the signature LED tails) This required adding an additional pin to the connector plug, and this is done and ready to go.
These notes are direct from the manufacturers website. Please take note:
- All Fords with Factory LED Tail Lights will flash faster on the dash, however the lights are still operating correctly in those cases.
- Factory LED equipped Broncos will not need to activate the turn signal function in Forscan if installing with 5915-FB-023
Interestingly enough, my Bronco came with the signature LED lights and I did not experience the hyper flashing nor did I make any mods via Forscan. YMMV, but just so all are aware. All other information and some install videos can be found on the Oracle website.
Something you'll notice...one of these is a little dirt and the other has plastic on the face. I bought the set of tails in November 2024 and installed them shortly after. Right around a year later, the passenger one started to have a failure in the brake light area. They have a 2-year warrant and Oracle sent me a new one, no charge. In the meantime, I needed to put my OEM tails back in to keep driving the Bronco and I have just decided not to put these back in.
Out of all the aftermarket tails available now, I still think these are the best looking. This is a huge missed opportunity for Ford, in my opinion, and this is how they should have come from the factory.
All that said, I'd like to get $325 shipped for this setup. (for reference, retail on the tails is $589 and the turn signal modules $118)
please let me know if you have any questions!
Ford Bronco f/s: Oracle flush mount tail lights w/ dual function reverse turn signals IMG_1828
Ford Bronco f/s: Oracle flush mount tail lights w/ dual function reverse turn signals IMG_1829
Ford Bronco f/s: Oracle flush mount tail lights w/ dual function reverse turn signals IMG_1830
Ford Bronco f/s: Oracle flush mount tail lights w/ dual function reverse turn signals IMG_1831
Ford Bronco f/s: Oracle flush mount tail lights w/ dual function reverse turn signals IMG_1832
Ford Bronco f/s: Oracle flush mount tail lights w/ dual function reverse turn signals IMG_1833
Ford Bronco f/s: Oracle flush mount tail lights w/ dual function reverse turn signals IMG_1834
Ford Bronco f/s: Oracle flush mount tail lights w/ dual function reverse turn signals IMG_1835
