Baja Bronco
Baja Bronco
2Sun AZ
Yikes! I have the newest kit, and they were supposed to have worked all of that stuff out. I got lucky, that it didn't bust all the way through. Looks like on mine it was installer error, they didn't clock the shock correctly, to where the hose fitting is closest to the body of the vehicle. Looks like my shop is going to take care of me, and handle everything.
I can't make the June run, but would jump on a Sept or Oct run in a heartbeat if it became available!
September is sold out. I’m hoping that next year they can get a Bronco run to La Paz, like the Raptor runs. That would be awesome!
Migo
Roy
Houston, TX
www.instagram.com
I'll probably add the Foutz rear bumpstops. Moving the King reservoir wont be too hard. Yu can go vertical toward the front of the wheel well by just trimming the fender liner some. I think Shredder has rear King's and bump stops her setup might be worth a gander.
I am looking to do the same relo with my King reservoirs to add Foutz rear bump stops. Any chance you have any pictures of your setup or Shredder that you mention above? Thanks!!
