Exhaust Mode on starting
bajabronco57
Nor Cal
4Runner
Does the Raptor have a "my mode" or similar? On my '22 Mustang GT w/ active exhaust, I can set the exhaust mode in one of the "my modes" and have it set to quiet startup that way.
As far as I can tell the Raptor starts up in the GOAT mode you have selected. There is no actual Quiet GOAT mode so the best I've found is leave it in Normal. You can have a Raptor preset which is where I set my preferred driving modes. Normal isn't terribly load especially if you're not out-front revving the engine, it's no worse than most the other trucks around. Once I'm a block or two away I hit my preset which is mainly sport mode settings except for the Engine/Shifter because it just keeps the RPM's far to high during a down shift for my liking. Sport mode is great in manual mode but I'm not a fan in automatic.
kennyle1990
Kenny
Vancouver, WA
2023 Bronco Raptor
I quickly glanced through the two pages so apologize if someone said it already, but you can change this in your Braptor settings so the car starts in quiet mode. You probably found this out already given the date of this post!
lewishamilton
lewishamilton
Canada
17 VW Golf R
Hi, thanks for the info! Actually I haven't found any solution yet. Can you let me know which setting is that? I can't seem to find it.
DucatiExplorer
M
Delta
2023 Bronco Raptor
Hey buddy,
Page 262 of the Ford Owners Manual:
  1. Quiet Start
    Quiet start allows you to schedule when the exhaust mode turns on the quiet setting. The time window can be from 1 to 24 hours
    Enabling and disabling quiet start:
    1. Press Settings.
    2. Press Vehicle.
    3. Press Quiet Start.
    4. Press Quiet Start.
    5. Press Settings.
  2. Setting quiet time:
    1. Press Settings.
    2. Press Vehicle.
    4. Press Set Quiet Time.
    5. Set your desired start and end times
This way you can program what times you want it to start in Quiet Mode.
In case you do not have the link to the online manual here it is:
https://www.fordservicecontent.com/...d_Bronco_Owners_Manual_version_1_om_EN-US.pdf
lewishamilton
lewishamilton
Canada
17 VW Golf R
Hey buddy,
  1. Quiet Start
    1. Press Settings.
    2. Press Vehicle.
    5. Press Settings.
    1. Press Settings.
    2. Press Vehicle.
Thank you so much for the instructions. Not sure why I don't have this in my settings... maybe this is only available for 2023 models? Mine is a 2022 Canadian model.
Ford Bronco Exhaust Mode on starting 20230827_183658
Ford Bronco Exhaust Mode on starting 20230827_183649
kennyle1990
Kenny
Vancouver, WA
2023 Bronco Raptor
Sorry for the late response but it looks like someone beat me to it.
here’s my screenshot if it helps
Ford Bronco Exhaust Mode on starting IMG_1296
lewishamilton
lewishamilton
Canada
17 VW Golf R
Thanks! Unfortunately I actually don't have this in my 22 Raptor. (#20 are my screenshots)
