Not starting
Dbraptor
Damian
San Fernando Valley, CA
96 Cobra,Ranger,fj62. waiting on Bronco n Raptor R
So a couple weeks ago my Braptor wouldnt start. Had power and all, but it will just make a click noise but not start. Dealer replaced battery and starter. Worked for about 2 weeks, i was in SD and then again same issue. Got it towed to a local dealer in SD and it started. So I drove back home since it started. Dropped it off to my dealer and they can’t figure out anything. So I gotta keep driving until it does it again.
Anyone having this issue yet??? I know of a F-150 Raptor having this issue.
AreUgettingEnufCaffeine
JD
Ohio
2023 Bronco 2 Door
I thought I read about a cable connectors to the battery being loose and causing people to stall out/not start.. browsing the keywords to see what yrs etc affected.
Edit: it was a 2.7 badlands with a thread broken off the starter, You already got a new starter and battery..so still at square 1
Sir915
Shawn
El paso
2023 Bronco
I would check all grounds at the worst you checked it off the list of potentials.
kodiakisland
Arkansas
Dbraptor
Dbraptor
Damian
Ive checked them and the dealer did also. They said everything checks out fine. They will have it for a couple more days and see if anything happens.
Gypsy
Maria
We went through the same thing with our Jeep. We even went to different dealerships when we took a 1500 mile trip and it wouldn't start after getting gas. One dealership took the gearshift apart and said it was twisted out of gear:sadface: Finally a dealership figured out that it didn't recognize that it was in Park. It had a faulty module that had to be replaced. I don't know if that is Braptor's problem. I hope you get solved soon.
JD
Ohio
2023 Bronco 2 Door
I'm going with The Fuses or The Negative Battery Terminal connection, hopefully something easy and not too time consuming..
Funny thing about mine on my 3rd day of ownership, My charging ports all fried out.. very annoying 😒
Ford Motor Company
Official Ford Account
Dearborn
Bronco, Bronco Sport
Good afternoon. Would you please send over a private message with your VIN and dealer info so I can look into this starting concern on my end?
  • Haha
Reactions: Dog
Dbraptor
Dbraptor
Damian
Dead again. Yet the dealer can’t find anything wrong when they have it.
GATORFAN99
TN
2022 bronco raptor
I am having the same issue. Sitting at the dealer right now and they are stumped. The can jump it and it runs but they can't get it to start on a battery. This is a major issue.
Dbraptor
Dbraptor
Damian
so they replaced some fuse panel and ecu on mine. Haven’t had anymore issues
GATORFAN99
TN
2022 bronco raptor
Still no resolution from my dealer, they can not fix it. Time for a warranty act claim? It’s been at the dealer since 6/18/24, today is 7/13/24. Worse yet, they don’t even bother to call me to tell me what they are doing.
