Exact MM for Squatch speedo 2mph fix?
WuNgUn
Ontario Canada
2 door Squatched
  • Thread starter
  • Banned
  • #1
Speedo calibration using ForScan...
I have Squatch pack from the factory but I just have to recalibrate speedo to get rid off the 2mph error Ford put in there.
Anyone know offhand what millimeter value they used to correct the error?
Thanks
Edit: the magic number for stock Squatch Bronco's is 2600mm
BlazinGTO
Dustin
MA
2004 GTO M6 2004 Escape
Not sure which way it's off.
At 334mm 65mph would now read as 66.98
At 296mm 65mph would now read as 63.02
WuNgUn
WuNgUn
Ontario Canada
2 door Squatched
  • Thread starter
  • Banned
  • #3
2653mm is the stock Squatch number....
Speedo reads 102Km when I'm actually doing 100km
2% difference...
Not sure if I have to go bigger or smaller.
-2% is 2600mm
+2% is 2706mm
Waiting for my extended license renewal email to show up. Ugh
drew707
Ford Explorer
I think there’s a speedo calculator around here that tells you how to get it dialed exactly. You use GPS and you can input the gps speed and your Speedo reading and it’ll spit out the correction. Unless I was drunk but I’m pretty sure it exists.
WuNgUn
WuNgUn
Ontario Canada
2 door Squatched
  • Thread starter
  • Banned
  • #5
I think there is one on the ForScan spread sheet.....? Trying to find it
WuNgUn
WuNgUn
Ontario Canada
2 door Squatched
  • Thread starter
  • Banned
  • #6
It was the power point time out calculator... I was wrong
drew707
Ford Explorer
Yesss I think that’s where it was. Either ours or the 2021 F-150. The 2021 and up models have their own unique quirks but I think you’re past those parts.
Found it
zuke
Stafford VA
You should first figure the percentage you are off, say 80mph indicated is actually 82mph...
2mph is 1.6% of 80mph...
Then figure out what percentage of the current circumference is 1.6%
2653/100 = 26.5
26.5x1.6 = 42.448
If you're speed reads High, Subtract the number from the circumference value
2653 - 42 = 2611
There you have it!
WuNgUn
WuNgUn
Ontario Canada
2 door Squatched
Found it
Thanks Drew... But WTF is that!? It opens in Chrome but I can't make a copy to use the calc...
Wtf made that?! 🤣🤷
WuNgUn
WuNgUn
Ontario Canada
2 door Squatched
2653/100 = 26.5
26.5x1.6 = 42.448
2653 - 42 = 2611
There you have it!
Thanks... I'm 2% off, reading high...
I'll make adjustments to subtract 2% from my stock value.
2599.94 so 2600 👍🏻
Thanks!
Tricky Dick
Dick
PNW
www.TD-Distributing.com
For some reason this whole speedo recal thing doesn't feel like an exact science, which is weird because it should be.
On factory 285s my speedo read 60 and I'd be going 58. Now on 315s I'm going 61 when it says 60. I chose to leave the factory number alone, which was 2525. That sounds waaay too low based on all these calcs that show 26xx or even 27xx.
BlazinGTO
Dustin
MA
2% difference...
-2% is 2600mm
+2% is 2706mm
Lol my numbers are junk. Sorry, I tried to use an online calculator and did it incorrectly.
I'd say a lower number would reduce the speedo.
WuNgUn
WuNgUn
Ontario Canada
2 door Squatched
I have a DTC I can't clear..
Could not find AWD relearn... Only reset.
I did the PCM reset adaptations and reset AWD, but still have error
Ford Bronco Exact MM for Squatch speedo 2mph fix? 20220608_120442
