Everglades Snorkel Photo Request
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Hey guys. We're looking to improve some of our products and I'm hoping some of you with an Everglades can post some photos for us that will help us out. We don't have an Everglades in the shop anymore.
Could you take some photos of your snorkel mounting system? The part that bolts the snorkel to the cowl is what we're after.
Thanks.
CitrusBronco
Everglades
Citrus county, FL
Everglades
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
CitrusBronco
Everglades
Citrus county, FL
Everglades
This is another angle of what of Glade Runner shared.
Ford Bronco Everglades Snorkel Photo Request IMG_1639
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Are you just wanting a photo of the exterior bracket?
Yeah that kinda works, thanks.
Any way to get a photo of the underside of the bracket, where it mounts (and it's hidden by the actual snorkel). Meaning... WHAT is under the actual snorkel? There's another bolt i think, right? It's under neath in that cavity that I have marked... I think there's another bolt right. The cowl has 2 bolts. One is clearly visible but the 2nd one that is under the snorkel... is that actuall attached to the snorkel?
You can kind of see it in your 2nd photo but hard to make out.
Ford Bronco Everglades Snorkel Photo Request 1767905653129-10
Ford Bronco Everglades Snorkel Photo Request 1767905593759-3v
CitrusBronco
Everglades
Citrus county, FL
Everglades
This link I added has views of the bracket from all angles https://www.ford.com/product/bracket-p4000045655
If you are interested in what the bracket mounts to, the bracket sits directly on top of the cowl and mirror arm cover. Split 50/50. And is held on with those same 2 bolt holes.
Ford Bronco Everglades Snorkel Photo Request IMG_1640
Ford Bronco Everglades Snorkel Photo Request IMG_1641
4x4TruckLEDs.com
4x4TruckLEDs.com
Adam
Lindenhurst, NY
OKAY yeah thanks that's what we figured. I think people are using the wrong bolts when they install the bracket is all. We provide new flush bolts and I guess people are not using those (and they should)
