Engine power issues with 37's?
EOSeabee
Patrick
Las Vegas
2022 Ford Bronco 4 Door Badlands
I just had my lift installed. Fox 2.1 coil-overs, Icon tie rods, and Elevate UCA's. Haven't maxed the lift yet. At this point it's just leveled. I do go out rock crawling as often as I can and want some more clearance. I'm wanting 37's, but I have a friend that thinks 37's will kill my power. I have a '22 Badlands Sasquatch, with 2.7. Anyone have any thoughts on the power issue?
malpais
Some old Honda
With a 2.7 and a 10-speed trans, I doubt you'll have any issues. Your speedo may report your mph a bit incorrect, though. Assuming you also have a SAS then you have a 4.70 gearing and therefore it'll be fine (I'd even say the 4.46 can move 37s fine). If you really feel like it's a dog, you can go higher in the final drive.
swooshdave
Portland, Oregon
Mustang
Does your friend have a Bronco? Or are they just projecting?
EOSeabee
EOSeabee
Patrick
Las Vegas
Both! Lol. But his is a pavement princess. He has a friend who has a 2-door Jeep. He put 37's on it and the engine power went to crap. He ended up changing out his rear end. My friend also put 37's on his F-150 Raptor and had a similar result.
Tricky Mike
21 Bronco
The Jeep probably has worse gearing.
I did feel a big performance drop going to 37s. Premium helped a little, but I'm mostly just adapted to it now.
swooshdave
Portland, Oregon
Mustang
Did you go from 33s or 35s to the 37s? The other thing that makes a huge difference is that similar diameter tires can vary widely in weight, which is going to have a big factor in the power feel. There's a thread on the forum comparing the weights of varies tires.
Also the stock Sas wheels are silly heavy. Cut some weight there by going with some nice Methods.
Ninjak
Miami
Zero problems. I run Discoverer STT Pro's 37s on a 17-Black Rhino rim. Now mind you I do have a few engine mods. (in the sig) but loss of power is not an issue for me. On pavement or Off.
EOSeabee
EOSeabee
Patrick
Las Vegas
I'm running Method 17" Bead-grips with 0 offset. I'm looking at BFG KO2's, but then I hear they are phasing those out. The stock Goodyears are a little too squishy.
Tricky Mike
21 Bronco
The Goodyears which are probably closer to a 33 than a 35.
EOSeabee
EOSeabee
Patrick
Las Vegas
Really? Are you really going to go there?
To answer the question you were going from the Sasquatch 35s.
Yes, I plan on going to 37’s from the Sasquatch 35’s.
