Engine Oil Drain
buzpro
Binky
Tacoma
Has anybody taken any pictures of access to the oil drain valve? I've been to two events and I forgot to do it both times!
Razorbak86
Northwest Arkansas
Ford Bronco, BMW R1150 GS
DUSTYcazOREGON
Craig
Be prepared when that yellow plug come out (1/4-turn) it will empty the pan in about 5 seconds.
I wonder if we can replace it with a Fumoto valve?
DUSTYcazOREGON
Craig
I have been wondering if there is a skid plate to remove that protects it? I know even my Charger has a plastic weather protection (water) plate that needs to be removed to get access to the drain plug.
Silver-Bolt
Eureka, MT
DUSTYcazOREGON
Craig
buzpro
buzpro
Binky
Tacoma
Rick Astley
Up Doug's ass
d
the picture is good but i was looking for a picture of access in the car! I want to see how to get to it. Is it the same as the Ranger?
will be nearly the same as Ranger FX4. If you've already got the FX4 then you'll be used to removing a bash plate for full access to the drain plug.
Full disclosure: I have no clue what models other than Squatch/BD/BL/WT have factory bash plates, if you've got some base or OBX on order for the on-road lifestyle then it's probably a very easy oil change with about 2 tools needed, plus half a beer.
buzpro
buzpro
Binky
Tacoma
well, if its similar to the FX4 then a Ronin plug or similar is almost a necessity. (after the first free oil change)
Chuck_Ruck
Chuck
Arizona/Nomadic
F150, Wrangler, Eldorado, Harley, Triumph
On the 2.3 the skid plate is in the way, but the oil filter is easily accessed through the driver front wheel well.
Ford Bronco Engine Oil Drain 20210524_104515
buzpro
buzpro
Binky
Tacoma
aaaaaah the friggin skid plate!
Chuck_Ruck
Chuck
Arizona/Nomadic
I'm not complaining, just reporting.
Well I've seen other vehicles with skid plates have trap doors and port holes for ease of access. I might be inclined to create my own and weld in some reinforcements to the potentially compromised point of penetration.
buzpro
buzpro
Binky
Tacoma
that's a great idea .... would love to see what you come up with
