Emergency Winter Winch - Warn 3700
Ferd
Geometric center of a hostile state (NY)
F-350, Bronco
Hi all, newbie here. Just got a ‘24 Outer Banks, which is mostly a road vehicle, replacing a ‘20 Outback. I’t’s kind of a late life rebellion vehicle (i’m an old guy) without the perils of a Mustang GT. Open air and the potential of winding through the woods. Definitely NOT going rock climbing in NH or Moab, though (at the moment).
Anyway, the question is about winter operation in Northeast, A.K.A. the middle of the NY Snowbelt, and specifically about pulling out of ditches in rural settings. I have a Warn 3700 winch which was bought years ago and used about 4 times to pull my tractor out of some nasty situations, like blue clay up to the belly. Will that be adequate to pull the Bronco out? I have a correct snatch block for the winch. What else will I need? Recovery straps? How long?
I’m asking because most winch discussion is about 10k to 12k drag you up the nastiest grade installations, and I don’t want to go that far. Will my puny winch work for ditch dragging If I have the correct additional recovery tools, and what are they? Thanks!
Squatch
Ford Bronco Emergency Winter Winch - Warn 3700 1000014593
It could, but I would really make sure that it is well serviced and the snatch block is in good shape.
Maybe I am a bit overly cautious, but I got my gear at Factor55. We all saw the recent fatal winching incidents plastered all over YouTube and social media.
  • Like
Reactions: rws
DriveAllNight
Dan
N.J.
24 Wildtrak, 25 Audi Q6 etron Quattro
Depends on how stuck you are, and how good you are at pulley math. :wink:
Obviously your OuterBanks weighs more than your winch is rated for, but you can over come that with more line and doubling back and forth with snatch blocks .. it's just physics. It will take more time, but assuming the circumstances allows you to set it up properly, in theory you should be fine.
  • Like
Reactions: rws
