How AWESOME are you??!!Disable the double honk when exiting with the engine running
- Make sure Bronco is off and at rest
- Hold lock and unlock buttons down on the key fob 3 seconds until lights blink twice
- Release both buttons
- Press lock button
No more stupid double honk!
Doesn't work...Disable the double honk when exiting with the engine running
- Press lock button
If AZMike was trying to pull one over on us.....I've been meaning to road trip to AZ. I'll post up outside his house and jump in and out of my bronco for hours on end......Yea just tried the double honk. Doesn’t work.
Thought I'd post a couple of hacks that I've done to change some annoying things on the bronco. Anyone else have any?
Looks like Forscan is the only option at this point? May need to change the title of this post? " Eliminate annoying seatbelt warning when unbuckled"Double honk didn’t work for me. Any tips for the tips to get it to work?
New hack that is guaranteed to work... Remove all doors. Now you can get in/out all day long with no honk! Problem solvedDouble honk didn’t work for me. Any tips for the tips to get it to work?
With the key still in your pocket?New hack that is guaranteed to work... Remove all doors. Now you can get in/out all day long with no honk! Problem solved
You sir are a God amongst mere mortals!!!Thought I'd post a couple of hacks that I've done to change some annoying things on the bronco. Anyone else have any?
Good question? Does the proximity trigger the horn honk and will the vehicle realize you're out of the vehicle even though no door was opened/shut? Anyone with doors off try this yet?With the key still in your pocket?
I have but don't remember what happened... guess I'll need to take the doors off again.Good question? Does the proximity trigger the horn honk and will the vehicle realize you're out of the vehicle even though no door was opened/shut? Anyone with doors off try this yet?
