DV8 Offroad | OE Plus Series Side Steps
DV8offroad
Riverside, California
dv8offroad.com
Bronco's & Jeep's
2021-22 FORD BRONCO | OE PLUS SERIES SIDE STEPS
The OE Plus Series Side Steps for the 2021+ Ford Bronco were designed to offer an easier step up into your cab and provide light protection on the trail. These are perfect for those who will be running their Bronco as a daily driver, especially if you’ve given your Bronco a lift. The 2mm thick steel tube supports are topped by 3mm & 5mm thick steel plates with bike pedal-like teeth to provide sure footing when entering or exiting the cab.
Check them out here: https://dv8offroad.com/products/bronco-side-steps-oe
Ford Bronco DV8 Offroad | OE Plus Series Side Steps side-steps-bronco_1050x700
Ford Bronco DV8 Offroad | OE Plus Series Side Steps oe-plus-series-bronco-side-steps_1050x700
Ford Bronco DV8 Offroad | OE Plus Series Side Steps bronco-side-steps_1050x700
Ford Bronco DV8 Offroad | OE Plus Series Side Steps oe-plus-series-ford-side-steps_1050x700
Key Features:
  • 2mm Tube & 3mm Plate High Strength Steel
  • Micro-Texture Black Powder Coat Finish
  • Engineered for all 4-Door Bronco Trims
  • Easy Installation Using Provided Hardware
Technical Specifications:
  • Fitment: Direct Fit
  • Finish: Micro Texture Black Powder Coat
  • Material: Steel
  • Material Thickness: 3-5mm Plate/2mm Tube
  • Weight: 63lbs
***Note: These are designed to fit only the 4-door Bronco, they will not fit the 2-door models.
Visit https://dv8offroad.com/pages/ford-bronco-bumpers-and-accessories to shop all of our Ford Bronco Parts and Accessories.
Plus... use code "ForumMember" at checkout for 10% off!
irishdore
Tennessee
'23 Ford Bronco Badlands, '20 Ford Expedition
First, can I just say that I am appreciative that you have singularly called out that these meant for daily driver people and light trail duty. You've eliminated any confusion therein.
Question: tire size in your photos and up to what tire size do you feel this will work?
Question 2: fitment is listed as no drill in the technical specifications on the website, but to what does it attach?
Question 3: so, on a Badlands you'd remove the original rock sliders and install this instead? Pretty sure this is a 'yes,' like 99%, but you know what happens when one ass-u-mes.
Thank you
1979
Ben
Baltimore, MD
2023 Bronco Raptor
Curious about fitting larger tires as well. How do these fit in comparison to the factory sliders? Do they extend to the wheel well or stop short?
1979
Ben
Baltimore, MD
2023 Bronco Raptor
A better look at this photo answers my questions I believe. Looks like they don’t extend as far as the factory rails.
Ordering today. Thanks!
Ford Bronco DV8 Offroad | OE Plus Series Side Steps 79593B3F-EB82-4046-8AF4-9682AB98ADB6
irishdore
Tennessee
You've a better eye than me @1979 . Where are you looking to see that?
DV8offroad
DV8offroad
dv8offroad.com
Bronco's & Jeep's
Thank you
We have tested up to 38's and they fit just fine!
And you can check out the install instructions here to see how they are mounted: https://cdn.shopify.com/s/files/1/1...2_Install-Manual_Final_Draft.pdf?v=1649086685
1979
Ben
Baltimore, MD
2023 Bronco Raptor
The factory slider comes straight out at the front of the rocker. This one curves back sharply. It also looks shorter
Also looks like they’re running 37s in their photo.
Ford Bronco DV8 Offroad | OE Plus Series Side Steps 49AE7A2E-47C8-4C6A-A55A-796E5DCBB9F4
vs factory rail
Ford Bronco DV8 Offroad | OE Plus Series Side Steps F0376AB4-2F7C-4351-9012-223FE2F2C9F2
irishdore
Tennessee
Thank you, @DV8offroad . Favoriting this thread such that I may revisit when one day (who knows what day, not me) I actually receive my Bronco.
5280Bronco
Denver
Where are these produced? Just curious. Looking great!
DV8offroad
DV8offroad
dv8offroad.com
Bronco's & Jeep's
Our products are currently manufactured in China. Designed and engineered at our facilities in Riverside, CA and Mesa, AZ.
5280Bronco
Denver
Awesome. Thanks for the info. Definitely on the list. Thanks!
LoneWolf1903
Caleb
Tennessee
2021 Ford Bronco Badlands
Are these more steps than sliders?
DV8offroad
DV8offroad
dv8offroad.com
Bronco's & Jeep's
Sighlense
Upstate NY
2015 Mustang GT - 2022 Bronco Wildtrak
These are very sharp. My only concern is that it looks like the top plates are riveted into the tubes. That would not bode well over time. Am i correct, or are they screwed in? Also, are these ready to ship or is there a lead time?
1979
Ben
Baltimore, MD
2023 Bronco Raptor
Ordered these last Tuesday when I saw the OP. Received them today and got them installed in about 45 mins (including removing the OE rock rails.) Super easy install and I think they look awesome. Should make life easier for the wife and little one climbing in and out.
Ford Bronco DV8 Offroad | OE Plus Series Side Steps 330FCD75-D69D-41C2-ADB9-7C4C36E0DE55
Ford Bronco DV8 Offroad | OE Plus Series Side Steps FF4B32E8-E62A-41A9-B44D-A35750CC3AB9
