DV8 Offroad | OE Plus 2-Door Side Steps
DV8offroad
Riverside, California
dv8offroad.com
Bronco's & Jeep's
2021-2023 FORD BRONCO | OE PLUS 2-DOOR SIDE STEPS
The OE Plus Side Steps for the 6th Gen Bronco were designed with performance and style in mind. These robust side steps enhance the look of your ride, while offering a safe and easy step up into the cabin. Their construction consists of sturdy steel tubes topped with steel plates that are textured similar to bike pedals, offering solid footing climbing in and out of your 2-Door Bronco.
To protect them from corrosion, they are finished in a micro-texture black powder coat to provide durability and blend seamlessly with the rest of your build. These will clear up to 38-inch tires. Installation is a simple bolt-on process, and no modifications or drilling are required.
Check them out here: https://dv8offroad.com/collections/...ers/products/2-door-bronco-side-steps-oe-plus
Ford Bronco DV8 Offroad | OE Plus 2-Door Side Steps SRBR-05_Installed_05_1245x700
Ford Bronco DV8 Offroad | OE Plus 2-Door Side Steps SRBR-05_Installed_01_1245x700
Ford Bronco DV8 Offroad | OE Plus 2-Door Side Steps SRBR-05_Installed_02_1245x700
Ford Bronco DV8 Offroad | OE Plus 2-Door Side Steps SRBR-05_Installed_06_1245x700
Key Features:
  • Body/Pinch Weld Mounted Steps
  • Unique Gripping Solution
  • Adds Aggressive Styling to your Vehicle
  • Offers Protection from Light Trail Debris
  • Multi-Mount Design for Increased Support
  • Quick and Easy Installation
***Note: These are designed to fit only the 2-door Bronco, they will not fit the 4-door models.
Visit https://dv8offroad.com/pages/ford-bronco-bumpers-and-accessories to shop all of our Ford Bronco Parts and Accessories.
Plus... use code "ForumMember" at checkout for 10% off!
