DV8 Molle + AAL Cargo Shelf
JediMcMuffin
Tommy
2026 F-150 Tremor 401A
Has anyone installed both the DV8 rear window molle panels AND the AAL cargo shelf? I think I can make the two work together, but wanted to see if anyone else had pulled this off.
JediMcMuffin
JediMcMuffin
Tommy
@DV8offroad - any guidance here? I was thinking I could drill the holes in your bracket a bit to offset the AAL bracket already in that spot, no reason they can't both exist.
Ninjak
Miami
Which Molle are you speaking on for DV8? You have their straight ones, then you have their pocket ones. I have the pocket set. These set flush to the bar, and has the small indent in the bottom, thus creating a pocket.
I am also looking to do a shelf, I may try the Havoc one. I need to see how the AAL is set, but I do believe they can work together as well.
Pics below of how the pocket MOLLE looks installed. Hope it can help.
Ford Bronco DV8 Molle + AAL Cargo Shelf 1747094726580-34
Ford Bronco DV8 Molle + AAL Cargo Shelf 1747094783199-7x
Ford Bronco DV8 Molle + AAL Cargo Shelf 1747094819508-pf
JediMcMuffin
JediMcMuffin
Tommy
Probably the non-pocket set. Seemed to me like the pocket ones were meant for folks who run topless. I'll snap a photo of the AAL bracket on the roll bar. it definitely uses the same mounting point, so if i just use a drill press to elongate the holes in the DV8 bracket, I think it will work.
Ninjak
Miami
I picked up the pockets because of my gullwings. Able to store gear there is great. I have my air hoses in one side, and I can use the other for a myriad of things.
Interested to see how this works out, I still looking for what type of of shelf I should get. I wish I could use an MTM Actic shelf, but that slant-back life says no.
JediMcMuffin
JediMcMuffin
Tommy
I ended up going with Turn Offroad's Molle panels. I did have to invert one of their brackets, but the end result is absolutely fantastic. There is like 2mm of room between the AAL shelf bracket and the roll bar mount for the Turn panels, a bit tight but very strong. Also worth noting, the AAL molle solution I removed really is poorly thought out. It uses the hardtop mounting bolts instead of dedicated brackets, so should you remove your top, you have to put the bolts back in or bring your molle panels out with it. The Turn solution uses brackets into the roll bar, rear set belt mounts, and one of the 13mm bolts for the soft top mounting. I absolutely love the outcome here.
Ford Bronco DV8 Molle + AAL Cargo Shelf 1747765943122-hu
Ford Bronco DV8 Molle + AAL Cargo Shelf 1747765972767-pl
Ninjak
Miami
Interesting. So a few questions:
1) Does the AAL panel or bracket fit to the end of the MOLLE panel?
2) What do the two upper bolts connect to?
3) How big is the shelf? Does it take up the entirety of the rear space?
4) Can you take a pic of the OUTSIDE looking in? Or the other side of the setup?
Nice solution. Any squeaks or rattles? Not bad. Not bad at all.
1979
Ben
Baltimore, MD
2023 Bronco Raptor
How do you get to the hardtop bolts with these installed?
Ninjak
Miami
Those are the Hardtop bolts. They replace them. They are pretty stout. I do not have to worry about them coming loose.
1979
Ben
Baltimore, MD
2023 Bronco Raptor
Sorry. I mean how to you access the bolts with the molle panels installed? I actually have these same bolts.
Ninjak
Miami
Ahh Like this:
Ford Bronco DV8 Molle + AAL Cargo Shelf 1747782983493-gy
Ford Bronco DV8 Molle + AAL Cargo Shelf 1747783025494-k8
I have an ArmadilloHardtop. I have GullWings.
JediMcMuffin
JediMcMuffin
Tommy
1) Does the AAL panel or bracket fit to the end of the MOLLE panel? No. The AAL bracket wraps around the roll bar and has a bolt into the pre-threaded location. The TOR Molles use that same spot with an L bracket. The TOR bracket has enough play in it to make it work and the bolt is long enough that both brackets can use it.
2) What do the two upper bolts connect to? The TOR molle has three mounts. One is a bracket off the seat belt, one is off an L bracket on the underside of the roll bar, and the last one is a T bracket off the soft top mounting spot behind the trim panel. The upper bolts on the AAL shelf bracket are just thru bolts into nuts. There are 5 total bolts on the AAL install, one shared with the TOR bracket, the other 4 just clamp the shit out of the roll bar with thick foam in between.
3) How big is the shelf? Does it take up the entirety of the rear space? The AAL cargo shelf is nearly the same size of the load floor.
4) Can you take a pic of the OUTSIDE looking in? Or the other side of the setup? Stay tuned.
No squeaks at all. Tight tolerances, but there are gaps where they need to be.
Answers in-line above!
