Drivetrain drumming noise at low speed
Zack
2022 Bronco, 2021 Ram Rebel
Hi, wanted to check in. You still getting that sound? I'm about 8500 miles in, and I get the noise more frequently now. I can hear it drumming even when stopped, which is confusing because early on it seemed to be associated with drivetrain engagement. The pace of the sound definitely speeds up when accelerating though.
Are you still experiencing it?
Zack
Yeah… seems more noticeable now that it’s cold. I had originally thought it quiet down because it’s broken in more, but that doesn’t seem like the case and it may have been because the weather was warmer? I’m at almost 14k miles now.
I do have another oddity. When I’m driving and have to brake firmly at a traffic light and the light turns green before I can come to a complete stop, if I let off the brake and accelerate. I feel kind of a thump like the driveline or something was binding under the firm braking then it gets release when I let up on the brakes and accelerate.
does yours do that? Maybe it’s related?
Are you still experiencing it? Thanks for the video. I just noticed mine is exactly the same today backing out of the driveway.
lcb
VA
Yeah, I still get it. It's much more steady and frequent as the miles are stacking on. It's not any louder, per say, just more frequent. I don't know if It's constant or not though since I can only hear it when I'm at lower speeds. My husband has an F150 and I've noticed it in his truck sometimes too. I'm just under 9k miles, and he's around 35k without any issues. So, hoping it's nothing, but still bothers me cause it doesn't seem normal...
Curious why you only hear it in reverse. How many miles?
Zack
I get it on drive and reverse but under very little gas. It doesn’t do it in neutral or park. Only under load which is weird.
Zack
Just had mine looked at for the same noise. Dealer also drove one on the lot and claimed they heard it in the brand new one also. I’m at 6k miles. Guess ill
Keep crossing my fingers.
HarmCityHammer
Glen Burnie, MD
Bronco Badlands
Any updates on this? I’m having a similar noise, going to take in into the deale soon. Another member mentioned this here:
Ford Bronco Drivetrain drumming noise at low speed 0E2886C4-2028-4A3D-AD8E-2D5B8A238A3A
unfortunate
unfortunate
NA
This was actually another issue I’m experiencing. Not related to this thread I believe. But I have a leaky front pinion seal and the dealer has the part on order. It’s a waiting game now since the part is on back order. I will report if it fixes what’s described on that thread or even this.
VirginiaHeritage
Frank
ā€˜25 Bronco HE
Did you ever figure out this drumming noise? I’ve got it too. Just as you described.
Not the same thing as the humming that lead to a new T-case.
This sounds like low rpm exhaust noise, not only when creeping in 1st gear but sometimes briefly in 2nd gear when the rpms drop and I’m barely on throttle. Only happens in gear under load, not when parked.
It only makes me wonder because I never heard it for at least the first 10k miles. Is it just normal for a broken in 2.7?
I have the mid package with standard sound system so I don’t think ford decided to suddenly ā€œenhanceā€ my exhaust sound through the speakers with an update.
VirginiaHeritage
Frank
ā€˜25 Bronco HE
Bumping this to see if anyone has any updates or resolution.
Low rpm drumming, will do it in 1st until rpms pick up and momentarily in 2nd when RPMs drop again. Matches engine speed, not drivetrain. Tend to hear it when tooling around parking lots.
88 FoxBody
Dustin
Northern VA
1988 fox body mustang w/ 347ci motor
Just started to have the same issue also. 22 base sas w/2.7 and 27k miles. It’s going to the dealer tomorrow for some other things. I’ll add this to the list.
