Mechanical noise at low speed
Brsox
Bill
Rhode Island
2023 4Runner TRD Pro
2023 Heritage 2 door. 2.3/manual here. 5300 miles. Vehicle engine/transmission/clutch run nicely with no issues. However, at very low speeds, just around 5-10mph, in first gear, I feel like I hear a faint mechanical noise that sounds like it's coming from beneath the floor board, right below my feet. Could be nothing, and totally normal but just sounds a little odd to me. Noise goes away as soon as you get over 15mph. Has anyone noticed anything like this? Maybe it's just me 🤔.
Does same noise happen in say,1st 2nd or 3rd gear in 4L at same speed?
Could be a speed thing in the transfer case, or it could just be how 1st gear sounds. There are quite a few other things it could be too but that’s one way you could differentiate between the gear and the speed
83XLT
Carl
Cincinnati
22 EG Big Bend 2.7
may have a skid plate bolt that's worked it's way loose. That happened to me after an oli change.
John P.
Orange County, CA
BMW X5
I have that, too, also 2023 and manual. Dealer tech said it’s normal; not sure if it is since I haven’t been in another similar spec.
Brsox
Brsox
Bill
Rhode Island
I haven't tried checking in 4low. I'll get back to you on that.
thesocalexplorer
Joe
Southern California
Any difference in the noise when you depress the clutch?
The 7MT is sometimes a bit noisy when you're coasting in first gear under little to no load. Check out the manual transmission scraping thread and see if the noise is similar. I personally rarely get the noise but occasionally notice it when coasting in a quiet parking lot.
