Driver side mirror cracked no contact.
bkfit
BK
Spaceship
Side Mirror cracked. Supplier is SMR. Noticed today a crack no sign of contact. I don't use my interior rear view mirror. I mainly use the 2 side mirrors being its a base with out auto dimming, as well as my back soft top window is always dirty Mi. So I'm always looking/using this mirror & passenger, and just noticed it today. just a heads up, curious if anyone else has had this failure. Self cracking mirrors...
Ford Bronco Driver side mirror cracked no contact. warranty 1
Ford Bronco Driver side mirror cracked no contact. warranty 2
MN_OuterBanks
AW
Minnesota
2015 F150 SuperCrew
Nope but I have a self-cracking airbag cover on the steering wheel. Didn’t notice anything wrong with it, it got to -17 and boom! Hair line crack from below AIRBAG up around the bronco on the center.
bkfit
bkfit
BK
Spaceship
Pic? can you send a pic? Did you warranty it?
Paul Gagnon
Paul
Sherwood Park, Alberta, eh?
I had a mirror crack like that on my F-150. Ford would not fix it. It ended up being less hassle to replace the glass than fight with the dealer. Of course, being that Bronco mirror glass is probably hard to find you might want to take it in and see what they say.
Mine is not cracked but you can clearly see the outline of the cutout. Right now it is onl ugly but I will be keeping an eye on it for sure.
On my F-350, the airbag split open and they replaced it under warranty. Now 12 years later the second one has split as well.
MN_OuterBanks
AW
Minnesota
2015 F150 SuperCrew
Wonder if your steering wheel looks like mine. I’ll grab a pic of it shortly.
Techun
Pa
BD, 2.7, MIC, 4dr
Wait does yours have the little corner mirror?
...I have to go outside and look at mine now.
Yeah mine's one piece :(
bkfit
bkfit
BK
Spaceship
Ill contact the supplier, see about getting a replacement. I've opened a warranty claim...
Paul Gagnon
Paul
Here’s what mine looks like in the Bronco and the truck. Both times on the truck the cover split when it was very cold. I expect that the Bronco cover will also split because it is made from a more rigid plastic, in the truck it is more rubbery.
Ford Bronco Driver side mirror cracked no contact. E53593E7-80F7-4E3E-9219-E3C74FDCABF1
Ford Bronco Driver side mirror cracked no contact. BA57EBFC-CC53-48AE-9C3C-C2857949D69F
Ford Bronco Driver side mirror cracked no contact. 1DE47E41-B41B-4A2A-A855-F81E72E1AB2E
bkfit
bkfit
BK
Spaceship
bkfit
bkfit
BK
Spaceship
Holly massive Flow line I.M issue. That defiantly out of spec Per Ford Global standard.
Paul Gagnon
Paul
Really? that's odd? mines just a basesquatch.
Mine doesn't either and it is a Lux Badlands. I wonder if it is because of the blindspot monitoring. It should have both, I'd honestly rather have the convex mirrors if I had to choose.
Paul Gagnon
Paul
That's not a flow line, it's where the airbag cover is designed to split open when it goes off.
bkfit
bkfit
BK
Spaceship
That's odd! I'm sure someone has the details on here that can break it down...
