Door inserts
68CT Bronco
West Simsbury
68 bronco, 2017 f150
Any rumors on door insert availability soon after expected delivery date?
68CT Bronco
West Simsbury
The roadster (and my 68) has door inserts (at least that's what we called them 20 years ago). Remove door, install insert so the opening is not a big square. Probably using wrong nomenclature.
FirstOnRaceDay
Devin
Toledo Ohio
17 Civic, 19.5 Silverado
What’s a rumor (based off the Patents)
The door (maybe optional) will be a 3 piece door.
1 tube frame w/ buttons and speaker,
2 Inner plate
3 outer plate
so I wonder if the outer plate could have options like that.
MaverickMan
Shane
Ford Bronco Door inserts 20200704_105219
Something to match my 68. Safety Bars are unsightly
So isnt foam noodles ziptied to your rollbar:LOL: ... just kidding yourBronco is amazing and I dont know what I have that I wouldnt give for it.
MaverickMan
Shane
Door inserts do seem like a easy option. However learning from the old EBs maybe Ford made the door openings look cleaner with the doors removed. Rounded edges and tucked latch receivers maybe.
Deleted member 3063
Guest
I had thought that the removable part of the door attached to the side crash bars. If that's the case there would be no exposed latch or hinges to cover.
