Does the steering rack require lubrication?
Built2Wild
Bay Area
Motorcycle
I am doing some of my own maintenance and recently hearing the steering rack squeaking when I turn the wheel at a full stop or when I am crawling over obstacles. I know there's a lot of of conversation of HOSS 2.0 racks failing or overheating, I am trying to stay ahead of that. Therefore is there a steering rack lubrication maintenance I am overlooking?
Nc211
Washington DC
There are some comments about the knuckle connector needing a squirt or two of some wD40 if you find the steering doesn't want to spring back to center, the knuckle gets a little corrosion or something like that on it. Other than that, I've not seen much chatter about lubricating the steering rack as a preventive maintenance item. But I'm no wikipedia on the car either....
SuperDave150
Lubbock, TX
Ford F-150, Ford Edge
No.
SierraBronco
You can run the rack bar all the way out (disconnect the battery and be certain to measure how much you started out with to return to that) and apply this grease to both sides. Lube it up liberally and go back and forth all the way a couple times then remove the excess.
https://a.co/d/hRGdNHh
