Does HP play a big role in off-roading?
jay-rod427
Jerod
KS
Carbonized gray 2 dr BadLands Sans-Squatch ordered
Depends how you like to party. Google "rock bouncer" Horsepower can and will get you places lack of horsepower won't. Super slow easy rock crawling sure very little horsepower is needed. Mud bogging horsepower will DEFINATELY help. Insane hill climbing high horsepower is a must. High speed desert running ya you need some stout horsepower.
Again depends on what you want to do.
gentlemanbronco
Rick
ford fiesta 5.0
The 5th gen bronco had a big honking V8 that sounded awesome and made.....205 horsepowers.... The 2.3 will be just fine, the 2.7 will be even better but not really needed. Highway driving however....
cparksjr
Clayton
Linden, MI
2021 Bronco Badlands, 2020 Ford F250 Tremor
There are lots of different types of off roading, so I think it would need to be defined. Rock crawling which I know the least about, seems to need huge torque, not big high end power. Playing the sand dunes which is more my area, needs power and suspension. But even with that it needs to be best matched to tire size and gearing. I have seen many trucks with tons of power, and are beat by much lower power vehicles because of this. Weight is always a big factor too.
Raptor.Tremor.Bronco
Miami, FL
2021 Bronco Wildtrak, 2014 Raptor, 2020 Tremor
Just look at the ram trx, it makes so much power that it makes the vehicle very dangerous offroad and also makes it very unreliable. It's a balancing act between how much power, weight, durability you have. A trx has lots of power, huge weight and low durability. For the bronco I'd say it has adequate power, moderate weight and adequate to high durability. This same though process was in the ford raptor documentary from 2010
King Luis
Toronto
Volvo XC60 & MK5 Jetta TDI
Is HP and Torque needed when not on a paved road?
- Jeeps don't have much and they do just fine.
- Tires play a bigger role on and off road.
- Off road, you can only put down the power if you have the grip. If you need to tow/haul more, that's where you'll want more power.
wvmtneer
‘Merica
F-150
Hello all! I wanted to ask if power plays a big role in off-roading? I understand that it's nice to be able to flow/merge quickly through traffic, but specifically for driving on trails, sand, snow, etc., is there an advantage to having more power?
Will the 2.7 have a significant advantage over the 2.3 when not on a paved road?
Thanks for your time and input.
Ford Bronco Does HP play a big role in off-roading? 1617897670612
Rivers90
Ben
Southern California
2 Door Base Sasquatch
I have done many trails in a 4 Cylinder toyota mini truck with only 100hp. Power was never a problem off road. I did black diamond trails and went all over the place. For the street it could have used more power.
The 4 Cylinder Bronco makes more HP then any of the earlier Bronco models. It will be fine.
But more power can be more fun too. Also you can break more stuff. With the v6 you may really want the bigger m210 front axle.
For off road a front locker is more important then more HP. At least on the trails I have done. Lockers are like superman mode.
CarbonBronco
Tony
Socal
99 Toyota $runner
HP How Fast you hit The Wall
TQ how Hard You hit the Wall.
