Do I have to cut sub wires?
6GSooner
Coppell, TX
2025 Bronco
Or is there a harness that plugs into the connector?
2025 with B&O
6GSooner
6GSooner
Coppell, TX
2025 Bronco
Or do I wire the speakers directly to the amp?
RagnarKon
Ford Bronco, Escape, Focus
What are you doing? Adding an aftermarket subwoofer I'm guessing??
box986
Paul
NNJ/NEPA
23 GX460 22 Sport BB, 03 Caddy EXT PU, 96 Lincoln MarkVIII, 92 Toyota PU 4x4
I left harness in place & just tapped into the wires (solder method) but ran a new 8ga wire for the amp
Isn’t the B&O amp right next to the sub anyway? The wire would be like 8” long. Any harness installed in the front by the ACM wouldn’t have the sub output anyway - none of the models would - sub amp and powered output is always back mounted on the sub enclosure.
I would not cut the wire or try to reuse it with a new plug — Just run a new larger gauge wire.
cmtaz
AZ
2023 Bronco
If you have a B&O system, metra / red wolf has a harness that will plug in to the subwoofer plugs. They are the same as the dash speaker harnesses.The other ends are spades. Clip the spade off and you should be good to go.
Fast Eddie
Ed
NY
2025 4Dr OBX, 2025 Navigator BL
I just released the metal pins from the plastic plug that attaches to the subwoofer. I then pushed the pins into the pressure clamp on the new sub. The connection is solid.
6GSooner
6GSooner
Coppell, TX
2025 Bronco
I just want to make sure I understand 100%. Sorry I’m ignorant on anything more than basic audio stuff.
my power and ground go here:
Ford Bronco Do I have to cut sub wires? IMG_1317
My plugandplay wire goes from here to the pigtail into the B&O amp:
Ford Bronco Do I have to cut sub wires? IMG_1316
Then I can pull the wires from the plastic connector here and attach them to the kicker sub:
Ford Bronco Do I have to cut sub wires? IMG_1318
And I am not running any wires to the amp here:
Ford Bronco Do I have to cut sub wires? IMG_1319
