DIY trunk ceiling light (custom fixed position)
linda_aig
Lux Sponsor (Level 2)
Montgomery
bronco outer banks
Trunk ceiling light function:
Same as the original reading light function
Can be set to light up automatically when the door is opened, can be turned on manually.
Can customize fixed position
Many car owners have reported lighting problems in the trunk.
After the trunk is modified or the cargo is piled up, many lighting blind spots are formed.
This trunk ceiling light meets the individual needs of car owners.
Users can define the position of the trunk ceiling light according to the modification of their trunk.
The trunk ceiling light is fixed by the rough pasting process, which uses the existing rough surface of the original roof for fixing.
Ford Bronco DIY trunk ceiling light (custom fixed position) 01
Ford Bronco DIY trunk ceiling light (custom fixed position) 02
Ford Bronco DIY trunk ceiling light (custom fixed position) 03
Ford Bronco DIY trunk ceiling light (custom fixed position) 04
Ford Bronco DIY trunk ceiling light (custom fixed position) 05
Ford Bronco DIY trunk ceiling light (custom fixed position) 08
Ford Bronco DIY trunk ceiling light (custom fixed position) 09
Ford Bronco DIY trunk ceiling light (custom fixed position) 10
Ford Bronco DIY trunk ceiling light (custom fixed position) 11
Ford Bronco DIY trunk ceiling light (custom fixed position) 12
Ford Bronco DIY trunk ceiling light (custom fixed position) 13
Ford Bronco DIY trunk ceiling light (custom fixed position) 14
Ford Bronco DIY trunk ceiling light (custom fixed position) 15
DRC
Cedarpines Park, CA
22 Bronco
Installed this lamp right behind the tail gate window, attaching it to the Hard Top Rear Cap Trim Cover. Ran the wires behind the tailgate window seal and over to the courtesy lamp. The hardest part was getting the courtesy lamp out of the side panel. Worked great and now I can see in the cargo area at night.
AIGMUX
Los Angeles
bronco 2022
