DIY Sasquatch Mud Flaps
dcg2
Don
PA
Honda CR-V
Seeing a bunch of posts about really expensive mud flaps that seem less than ideal in addition to being quite expensive.
Here is a DIY approach that I have had on my Bronco for a couple of months now and I'm very happy with the results so far. These do require some fabrication. The trickiest part being the front flap mounts. I decided to make my mounts out of 3/6" A36 steel. (I called around and got a scrap piece for $25 from a local fabrication shop).
Here are the drawings for the mounts (front - the front's are "handed" so you need to make a mirror image as well - and rear):
Ford Bronco DIY Sasquatch Mud Flaps Front_Mount_Drawing
Ford Bronco DIY Sasquatch Mud Flaps Rear_Mount_Drawing
Here you can see the front left mount being fitted:
Ford Bronco DIY Sasquatch Mud Flaps front_mount_fittin
I used the "horns" that Ford mounts the anti-intrusion bars into on non-Sasquatch models to secure my mounts to the Bronco. Ford handily left a bolt in the horn that I simply reversed and mounted from inside the horn through the mud flap mount. Note this requires an 18mm wrench which I did not ever have a need for prior to this.
Some grinding is required to fit the mount inside the horn but not terrible job to fit them.
Here's what the front looks like installed:
You'll notice towards the "top right" of the mud flap a bolt securing the top of it.
A few things to note. The mud flaps themselves are made of out very flexible rubber flooring. Specifically this stuff:
https://smile.amazon.com/gp/product/B01DCR5D5E/
in order to make the fronts conform to the wheel arch and flare I "reinforced" the rubber flooring with some thin sheet steel (I used a shit ton of rubber cement to sandwich them together). This does a couple of things. First as mentioned ensures the flap can take the shape of the flare and wheel arch and second enables bolts to be used to attach the flap to the mount and the flare securely (essentially acting as a giant washer creating a sheet steel -> rubber flooring -> steel mount / flare sandwich. The sheet steel only goes as far down the flap as the bottom of the mount so the everything below the rock rails / steps is flappy rubber flooring only.
How is that top bolt attached to the flare you ask? Nutsert to the rescue!
Ford Bronco DIY Sasquatch Mud Flaps flare_nutsert
The "humps" that are located inline with the flare locks makes a perfect attachment point. Also not visible is I made a spacer for each side approximately 5/8" thick between the top of the flap and the nutsert to get the "look" right (see last pic).
Here's how it looks from the back:
Ford Bronco DIY Sasquatch Mud Flaps front_fla
The rears are much simpler. They are attached to a rear frame gusset. Just need to drill 2 holes in the frame (get a good drill bit!) on each side. You'll need to pull the wheels to do this. Also a little bit of trimming of the inner fender well is required. I used a coping saw to trim it (you only take 2" off the dangly bit in the middle).
Here's what the rear mount looks like:
Ford Bronco DIY Sasquatch Mud Flaps rear_mount
Just like with the fronts, I used thin sheet steel to create a "sandwich" with sheet steel -> rubber flooring -> steel mount. These bolts are a bit of a bitch to get in not gonna lie but a little fiddling and they're good to go.
Here's the "I identify as a semi" view...
Ford Bronco DIY Sasquatch Mud Flaps rear_fla
Pros:
About $150 all-in for all 4 wheels
Strong as shit - Act as anti-intrusion bars in the front
Flexible - literally... flappy mud flaps.
Looks - I think they look fine.
They work! - 100% less rocks thrown at the the Bronco and the guy behind you
Cons:
Somewhat involved fabrication
Need to add nutsert to flares
Need to pull rear wheels to drill holes for rear flaps
Need to drill holes in rear frame gusset
Need to use a tool to remove front flares
Not sexy... basic bitch mud flaps
Thanks for attending my TED Talk.
Ford Bronco DIY Sasquatch Mud Flaps front_sid
TheSSBoz
23' Wildtrak
(y)(y)
I have a follow up question: how many miles you got on those tires?
dcg2
dcg2
Don
PA
Honda CR-V
(y)(y)
10K when these pictures were taken. 2 rotations so far.
JT58Bronc
JT
Fl
I absolutely love and can appreciate the drawings with dimensions for the supports. I am an engineer by trade so I assume you must be an engineer or fabricator of some sort as well.
dcg2
dcg2
Don
PA
Honda CR-V
I'm kind of a mutt... mostly software guy but dad was an engineer so I guess it rubbed off!
He is always critical of my drawings because they aren't properly toleranced! :)
CARdiac
Joel
Maryland
Hummer H3 Alpha, MINI Cooper S JCW, TVR 280i
Anyone on here willing to make me a set of mounting bars?
Hill Man
Gerald
Bellingham, washington
Hi Don, thanks for sharing your work, based on your ideas, would there be an issue with just extending the crash bar out with u shaped channel instead of cutting, in respect to wheel clearances, extreme shock compression, or whatever. Thanks.
Ger
dcg2
dcg2
Don
PA
Honda CR-V
Ger
I'm going to say No because this photo is with the wheel turned not quite all the way.
It makes sense since they remove the crash bars themselves for the sasquatch package.
Ford Bronco DIY Sasquatch Mud Flaps 20220525_120431
yippeekiyay
Bend, Oregon
2021 2-dr Badsquatch, 1998 Land Cruiser
Great freaking job, and thank you for the details and for sharing! If my Rekgen's don't work out I am going DIY and anything I learn/add from this I will be sure to post back in!
NVCowboy
William
Henderson, NV
Dad doesn't like your drawings? How does he feel when you say things like steel/rubber/steel "sandwich." I understood, but you were speaking my language. Nice job all the way around.
UncleBuck
Washington
2011 Ranger XLT 4.0L - 4x4
I'm in the process of using your drawings to fabricate my own flaps (hope that's OK). I'm going with polyethelene plastic kind of like rokblokz. I'll post my finished result next week hopefully!
dcg2
dcg2
Don
PA
Honda CR-V
Cool! Can't wait to see them! I'm pretty happy with the rubber flooring, interested to see how the Poly holds up.
UncleBuck
Washington
I built my Mudflaps using your templates with slight modification and different flap material, more like the rockblokz. I haven’t mounted the rears yet but the front performed well on a Montana mule deer hunt and on other muddy roads around the PNW.
Ford Bronco DIY Sasquatch Mud Flaps 666BA287-19E3-48BF-8B5F-4B7AEFCC0D19
Ford Bronco DIY Sasquatch Mud Flaps 03B8AD83-D14A-4C3D-8D82-6DD426786750
Ford Bronco DIY Sasquatch Mud Flaps 8C61C49C-D578-4195-AF58-CD62ED38C7E6
Ford Bronco DIY Sasquatch Mud Flaps B6FCFFAF-A59F-4681-B8C6-642C08B01E64
Ford Bronco DIY Sasquatch Mud Flaps AC294E80-9B8E-407C-8F6C-1304F1F30FAA
Ford Bronco DIY Sasquatch Mud Flaps 5863DF3C-5AFF-4637-9C5F-681BBD01BDE9
Ford Bronco DIY Sasquatch Mud Flaps 7CB71BA1-655F-4462-8EBC-07BE07B2211C
Ford Bronco DIY Sasquatch Mud Flaps 5713735E-D164-4DA6-812B-BA31B1A62105
dcg2
dcg2
Don
PA
Honda CR-V
That's awesome!!!
