Diode Dynamics Stage Series Reverse Light Kit Question
BaseManSquatch
United States
Does anyone know if the Diode Dynamics Stage Series Reverse Lights (SSC1 Pro, SSC1 Sport, SSC2 Pro, etc.) have brake lights build into them?
I know they have "rec accents", but if I was to press the brake pedal or turn my hazards on, would the Diode Revere lights also turn red like my regular rear lights or blink when put on hazard? I'm deciding if I should just buy the bracket from them for $80 and lights on amazon for another $80 or pony up the $290 to $440 from them.
mikec426
Russellville, AR
22 4dr Sqtch, '04 Yam FZ1, 22 Versys 1k, 19 Ninja
I don’t know what a rec accent is, but they aren’t additional brake lights.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
They do not. It's just a red accent. The only lights that have a "brake light" are the C1Rs.
You can actually save $$ with our reverse kit:
https://www.4x4truckleds.com/dual-l...-diode-dynamics-lights-7-pin-trailer-harness/
If you have a trailer hookup this will save you $$ and be an easy installation
BaseManSquatch
BaseManSquatch
United States
How many lumens are the SSC1 sport, SSC1 pro and SSC2 sport and SSC2 pro?
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
4x4TruckLEDs.com
Adam
Lindenhurst, NY
swooshdave
Portland, Oregon
Mustang
I guess I was under the impression they were also brake lights.
Doing the install now. Getting the connector behind the taillight tucked in is wicked hard. Not a lot of room and the harness is stiff. Might not help it's below freezing...
BaseManSquatch
BaseManSquatch
United States
That's what I always thought too when looking at them.
Wonder if it's safe to run a pair of them on a bracket on the rear tire in red accent mode?
When you apply the brakes and your stock rear lights turn bright red but the Diode Dynamics don't turn bright red and just stay the same brightness it might confuse the person behind you. I still like them but I don't know why they don't have dual stage red brightness mode inside the circuit assembly.
swooshdave
Portland, Oregon
Mustang
As Adam mentioned above, our SSC1 / C1R configuration is the only Stage Series pod in our line up with a road-legal 4th brake light along with our red accent light.
Could you provide a new harness that only lights up the red lights on something like the SSC2 when the brakes activate? I'd take those over running lights. And then, obviously, the reverse would still work.
Or is it not legal to use those as brake lights?
Diode Dynamics
John C.
St. Louis, Missouri
www.diodedynamics.com
Ford Bronco
You can have the red backlight illuminate as additional red accent lights with your brake lights when activated.
Our vehicle-specific harness is a plug-and-play option but doesn't permit you to have the red backlight illuminate with your brake lights but act as running lights.
https://www.diodedynamics.com/stage...ng-harness-kit-for-2021-2023-ford-bronco.html
You would need to go with our Universal Reverse Light Wiring Kit to tap the backlight to your brake light function using the included t-tap relay wires.
Ford Bronco Diode Dynamics Stage Series Reverse Light Kit Question 1675282503686
https://www.diodedynamics.com/reverse-light-wiring-kit-w-running-light.html
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
I'm not too concerned about the pods staying red and not lighting up brigher red when the brakes are applied. Mostly because the third brake light is right above these lights anway, so if for some reason someone is staring at the Diode Dynamics lights, they won't miss the 3rd brake light right above it turning on.
Diode Dynamics
John C.
St. Louis, Missouri
Ford Bronco
There is a dual brightness with our new C1R SSC1 LED pods. This technology has not been implemented into our other Stage Series pods at this time.
Ford Bronco Diode Dynamics Stage Series Reverse Light Kit Question 1675290705719
Ford Bronco Diode Dynamics Stage Series Reverse Light Kit Question 1675290711129
BaseManSquatch
BaseManSquatch
United States
OK thanks for the explanation. So there's hope that maybe in the future the SSC2s will get brake tech installed in them.
swooshdave
Portland, Oregon
Mustang
Given that I don't need the switch (I already have an upfitter switch in the circuit) and power then I assume to enable brake lights I just need E & F? Seems too easy.
