- First Name
- Adam
- Joined
- Aug 30, 2021
- Threads
- 554
- Messages
- 6,154
- Reaction score
- 7,048
- Location
- Lindenhurst, NY
- Website
- www.4x4TruckLEDs.com
- Vehicle(s)
- 2018 Raptor & 2021 Bronco Outer Banks
- Your Bronco Model
- Outer Banks
- Thread starter
- #1
Introducing the next generation of compact LED lighting, the Stage Series C2 2.0 LED Pod! Building on the popularity of the original C2 LED Pod, the newly redesigned C2 2.0 packs even more power, light output, and versatility into the same 2-inch footprint. With its compact design, the C2 2.0 is a go-to for tight mounting spots–roof racks, roll bars, bumpers, A-pillars, you name it. Despite its small size, the new Max option delivers the highest output we’ve ever offered in a two-inch pod at 3900 raw lumens!
Order yours now, we have limited stock available: https://www.4x4truckleds.com/led-pod-lights/diode-dynamics/ssc2-2-0/
You'll also receive FREE COVERS when you order the lights from us. No coupon codes required! Simply add the SSC2 2.0 lights to your cart then add a pair of covers as well. Covers are available here: https://www.4x4truckleds.com/led-pod-lights/diode-dynamics/ssc2-2-0/accessories/
Choose Your Power Level. The C2 2.0 LED pod is now available at three different power levels. All options use high-intensity, automotive-grade LED emitters, and TIR optics for unmatched focus and overall output. The Sport model offers the best bang for your buck with high-intensity LEDs, while the Pro model takes things further with a noticeable boost in total power.
The new Max power level uses the same Osram HX Boost LEDs found in our highest-output SS3 LED pods, delivering 3900 raw lumens. That’s serious brightness from a pod that still fits in the palm of your hand.
Customizable Mounting. The C2 2.0 LED pod features three mounting points to adjust the pod’s height. The revised mounting bracket also allows for even more adjustment to the angle of the pod for a more dialed-in setup.
The C2 2.0 LED Pod Cover will help keep your LED Pod clean and protected from dirt, dust, or whatever else the road throws your way. These covers are made out of a durable polycarbonate plastic that gives your C2 2.0 LED Pod an extra layer of protection. They quickly snap on and off for easy interchangeability, no screws required! These covers come in black, smoked, yellow, amber, or clear. They are also perfect for states that require covers on auxiliary lighting.
Order yours now. We have limited stock available: https://www.4x4truckleds.com/led-pod-lights/diode-dynamics/ssc2-2-0/
