Diode Dynamics reverse kit?
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
Any chance you guys can put together a diode dynamics reverse kit? I think the SSC1 or SSC2 with red backlight hooked up to the parking light circuit would look good.
I'm running a Curt Hitch and think an SSC1 would fit perfect here:
Ford Bronco Diode Dynamics reverse kit? PXL_20211107_220241823~2
BroncoAZ
Mitch
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
We could, but it would require a new style harness in order to have the red lights work. We've honestly never been a fan of those style kits (which is why we never offered them for the Raptors). Between the tail lights and your 3rd brake light there's a lot of brake light illumination back there already.
With that said, we DO offer the SSC1 and SSC2 on our site, and if Diode decides to make a plug and play kit we'll sell that, but for now, our only "kits" we offer for the Broncos include Baja Designs S2 which let you control the light from an upfitter AS WELL as automatically while going into reverse
https://www.4x4truckleds.com/2021-ford-bronco-reverse-light-kit-w-baja-designs/
The main reason we don't offer it, is because Diode uses a different connector over Baja and it would require us to make a new harness... but we'll look into making one based on our current design. Figure another 1-2 months before it's available though.
Bigmoose
Bigmoose
Jon
RI
Understand the complexity of an additional harness to offer.
How bright are the backlights? I was thinking they would be used as more of a running light and not a brake light.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
They are not that bright. You'll see them when they are lit up.
NatureMan
United States
@4x4TruckLEDs.com How does light output compare (pictures instead of just looking at specs) with s1 vs s2 sports for wide/cornering lights for reverse?
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Roughly the same comparing an S1 to an S2 Pro. S2 Sport has less light
