Diode Dynamics Lighting
HorizonHunter
Joseph
Chapel Hill, NC
Grand Cherokee Trailhawk
I have a full line of Diode Dynamics lights on my bronco:
* SS3 Ditch lights
* Series 6 fog lights
* 30' light bar
Easy install and they all work great!!
What did you do for the backlight on your a pillar lights? I can't find anyone that connected it to DRLs, and I don't want to put it on a second switch. Looking for direction on how to accomplish.
nbdybeatsthewiz
Denver
Badlands MT
I don't have the backlit pillar lights, just the basic SS3 pods
juniorobx
new york
ford bronco OBX
you ever figure this out ? same issue here
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
Fuse tap. Simple. Plugs in-line with an existing fuse circuit, gives you a little power leg for the DRL. Problem with that is, you can't turn it off. It's always on or off.
juniorobx
new york
ford bronco OBX
I think I may try running it to parking lights. I have my fogs already t tap into them now. just gotta see how i’m getting the wire from pillar to headlight harness
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Use this product from SPV to tap into your headlights for parking/running lamp signal:
SPV Parts Harness System Bronco Parking/Headlight Connector Adapter (P (specialtyperformanceparts.com)
I'm currently using this for my Rigid Radiance fog lights to trigger my amber backlight instead of using another aux switch or a fuse tap. So my backlights come on with my headlights or parking lights. In the next week I'll be adding A-Pillar / Ditch Lights with an amber backlight and am going to tie those into this same wiring harness.
juniorobx
new york
ford bronco OBX
Ford Bronco Diode Dynamics Lighting 3D107D06-4282-4513-8B39-F3112FB8EB55
got impatient. wired it to an aux , maybe will change it when it’s not winter lol
HorizonHunter
Joseph
Chapel Hill, NC
I'm electrically ignorant, but this seems like it would make sense over taps as other backlights get added. Any chance you can document your install? Trouble visualizing what connects where.
Lèòn
Jersey
Ford Bronco Diode Dynamics Lighting 9853E28F-D588-4872-A9FC-D6F395D35BFA
Got 4 ss3’s and 2 ss2’s for fogs, love them
if I had the money, do the bumper pods as well, also figure out how to wire them. Definitely no such thing as too much lights
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Here is the install video from SPV on how to do it. It's plug & play into the passenger side headlight, but requires loosening your airbox and removing some trim for wire concealement.
2021+ Ford Bronco - Installing the SPVparts Marker Adapter for Rigid Industries Radiance Backlights - YouTube
HorizonHunter
Joseph
Chapel Hill, NC
Thanks. Gonna have to do some routing with backlight wires over by the fuse box.
FowlBronco77
Everglades
Southeast MO
F150, Explorer, Bronco Everglades
Everglades
Just ordered some DD fog lights. Really looking forward to getting them installed. 4x4truckLED folks are great too.
4x4TruckLEDs.com
Adam
Lindenhurst, NY
Thank you, we appreciate the business. You'll love your kit. Everything you need is included.
Lèòn
Jersey
so thats what I need? I want my pods to work when its just runnin, disappointed I gotta use aux switches and this is just exposed like this
Ford Bronco Diode Dynamics Lighting 6E681FBF-FD62-47D7-BF36-8C3B6773C063
Still, major upgrade compared to the old stuff
Ford Bronco Diode Dynamics Lighting DEA5A76A-2AE9-47EB-9019-7838C2BC9B59
Ford Bronco Diode Dynamics Lighting 5C4C72B3-2614-4784-B28C-A92625566259
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Yes, use that. The amber backlighting will only work when your headlights or running/parking lights are on. It won’t work if the Bronco is just running or DRL is active. Has to be headlights or running/parking lights.
Not sure what that mess of exposed wires is in your pics.
