Diode Dynamics Chase Light Is Here
4x4TruckLEDs.com
Adam
Lindenhurst, NY
www.4x4TruckLEDs.com
The new Diode Dynamics Chase Light is Here!
Built to upgrade rear visibility, utility, and style in one compact universal setup.
Get a programmable amber chase light, high-power brake light, and white reverse light in a clean package made for trucks, UTVs, overland rigs, and more.
Mount it almost anywhere, wire it your way, and change patterns in seconds with SmartTap® programming using the included magnet tool.
Choose from 20 chase patterns for the trail, camp, or jobsite, then dial in your brake mode with solid output, triple-flash SafetyStrobe, or off-road pulse.
Available as a 10" Light Bar Here: https://www.4x4truckleds.com/diode-dynamics-ss10-10-led-chase-light/
or
We also have a Spare Tire kit available for those who want a "plug & play" installation (the only real wiring you have to do is connect the upfitter pass-through behind your rear seat to the cable we provide): https://www.4x4truckleds.com/diode-dynamics-ss10-chase-light-reverse-light-kit-for-2021-ford-bronco/
Ford Bronco Diode Dynamics Chase Light Is Here 1778862314281-qh
Ford Bronco Diode Dynamics Chase Light Is Here 1778862321478-c
Ford Bronco Diode Dynamics Chase Light Is Here 1778862330349-ki
Ford Bronco Diode Dynamics Chase Light Is Here 1778862340014-q2
Ford Bronco Diode Dynamics Chase Light Is Here 1778862348566-k8
Ford Bronco Diode Dynamics Chase Light Is Here 1778862355585-8
