Diode Dynamics 2021+ Ford Bronco SS3 Ditch Light Kit
Mitch Panda Motorworks
Mitch
St. Louis, MO
www.pandamotorworks.com
2021 Ford Bronco, 2014 Fiesta ST
Diode Dynamics stopped by today to check out our Bronco and get some initial measurements and insight for R&D purposes. In the Process, we installed a set SS3 Pro Combo Pods using the factory mounting location. This upgrade is a MUST HAVE for any serious Off-Roader. We have the kits available for sale using the link below! If you do not have the optional Auxiliary Switches, you will need to select the "No" option when prompted to receive a wiring harness for proper install.
Purchase Here: https://www.pandamotorworks.com/col...co-ss3-ditch-light-kit?variant=40406183805090
Mitch
St. Louis, MO
We are also running a new promotion! If you spend over $100 on Bronco products on pandamotorworks.com and use code "Bronco6T" you will receive a Free T-Shirt! If you spend under $100 you will receive a t-shirt at 50% off, just use code "Bronco6T50"!
Ford Bronco Diode Dynamics 2021+ Ford Bronco SS3 Ditch Light Kit 217482844_951896152331978_5533010637316122217_n (1)
BroncoKong Jr.
Andrew
So those are 3" lights, correct? Is there any interference with the antenna? And if not, If the lights were bigger would there be?
chris@pandamotorworks
St. Louis
2016 F250, 2013 Ford Focus ST
Yes they are a 3Inch Pod.
This is really the largest pod you can fit because of the antenna on the passenger side.
We have a video coming out soon that will help explain all of this about the antenna and how we lined ours up for best fitment and light output
604Bronco
British Columbia
www.bronco6g.com
I always laugh when someone says lighting is a MUST HAVE for serious off-roading 😄😄
If you’re not able to completely blind a deer on the trails, are you really off-roading? :unsure:
BroncoKong Jr.
Andrew
Ford Bronco Diode Dynamics 2021+ Ford Bronco SS3 Ditch Light Kit ss3___c2_standard_bezel_dimensoinal_drawing_1_4
Thanks. I suppose a slightly offset bracket could be fabricated to take care of that issue? Really terrible antenna placement lol
St. Louis
We will be looking at some bigger pods soon to see what could be done!
De Brus
De Brus
Washington state
'14 HD 1200, '66 IH, '62 VW
I would love to see some pics that aren't so close up. Showing the entire vehicle with both lights if possible. And aren't there multiple lighting options with the pro? How do you toggle through them with the aux switches?
St. Louis
Here are a few pictures that show what they look like on the Bronco :)
as for the options they sell different lenses for different outputs, we feel the Combo lens is the best suited for this position as the bottom half is projected down and the upper half is projected up and out.
If interested in a different lens we can help with that no issue
